Are the TJ hard tops all the same from 97-06? The jeep I just got only has a soft top and I would like to look for a hard top.
They are all the same. The only difference is that the 97-02 models have a vertical vent on the rear, whereas the 03-06 does not. Other than that, they are 100% interchangeable.
If you have a 97-02 TJ I would insist you get a 97-02 TJ. The vents are in the hard top for a reason for that generation and prevents a really annoying whistling when the AC is on. If you have an 03-06 TJ then you can use any hard top 97-06.
Do you drive with the windows down/cracked? Do you use the AC with the windows up? Are the floor plugs removed? I have not seen one 97-92 TJ with an older model hard top that did not whistle. I have however experienced 3 different 97-02 Jeeps that did whistle with the later generation hard top.I had a '05 hard top on my '00 TJ and it never whistled.
I have all the vents! LOL
That's really interesting. I wish there was a definite answer why or why not it would happen then.Nope, no whistles and everything was sealed tight. Maybe it was just a fluke.
This is a working Jeep Forum post link that goes into detail about it:Well, how does a whistle work? It seems to me that a very small air leak would create a whistle as internal pressure is built .. a large air leak or vent would equalize pressure resulting in no whistle at all.. a tight cab would just build pressure until it has a chance to equalize and a whistle may or may not start once the pressure starts to equalize depending on where it equalizes at.
https://goo.gl/zv4L9q
Every hard top I've had (and I have had a few) created the same issue with the doors closing. I think they just force too much air in at one time for any vents to really help.My 03 has a 03 top. No whistles, but my doors are hard to close when the windows are up. Maybe a 97-02 top would work better for that?
I liked your explanation....Well, how does a whistle work? It seems to me that a very small air leak would create a whistle as internal pressure is built .. a large air leak or vent would equalize pressure resulting in no whistle at all.. a tight cab would just build pressure until it has a chance to equalize and a whistle may or may not start once the pressure starts to equalize depending on where it equalizes at.
