1999 TJ 2.5 cranks but no start
Good point! I will check the notches and count them. But from what I found flywheel for 2.5 is the same over the years
how about the crankshaft sensor it’s just a Hall effect responding to the notches ? The connector is the difference between the years right?
I think any changes would be at the connector as well. You said it did run once? Bench testing a Hall effect sensor you can’t duplicate the speed it switches at when running or cranking. It’s hard to say for sure.
Found this on the internet
Will remove lower plate at bellhousing and see if I will find this flywheel of an yj.
Still doesn’t explain the time I got it running but have seen stranger things in life
Are you sure he used the correct flywheel? Just a random thought.
I looked, they seem to be the same from 95-02’ for a wrangler 2.5.
You where right, pulled the engine this doesn’t look like the right flywheel to me. Will install the right one and let you guys know. But I think I found the problem.
Flywheel fixed it, engine had a yj 2.5 flywheel. A lot more notches then the tj 2.5 flywheel.
New problem when engine reaches 75 degrees Celsius. It stalls.
I think it’s the o2 sensor.
That’s another odd symptom. I have not ever heard of an O2 stalling an engine. More backprobing and testing for you I guess. Good luck.
