Little update for today. I’ve put 300 miles on the transmission, with no issues so far.
I grabbed a buddy’s computer and did the quick learn procedure on the transmission. IMO this should be done any time you do an overhaul, and maybe even after fluid flushes. Quick learn uses the the clutches, solenoids, and fluid, to test the quality of all three components, and create shifts based off of the wear. Some say resetting the adaptive memory can do this, but that’s flat out wrong. The procedure it had me use was press the brake, and shift to N. I could feel the engine RPMs increase as well as feel the transmission move internally. Then it told me to shift to D. The transmission tried to “go” while I held the brake, probably testing the components. Then it told me to shift to P, and it was done. Took all of a minute, but extremely necessary with electronic Chrysler transmissions. So I have peace of mind knowing everything is where it should be.
As for the fun stuff, I retired the hard top for the next several months as the AZ weather I was trying to beat with the swap is here! Doors came off as well and made for an extremely pleasant commute to school and back today. My classmates even hopped in with me when we went to lunch. It’s a Jeep thing I guess! It looks good from every distance and angle.
