I saw this on TV the other day, has anybody used this? I would like brighter lights, but want to keep the classic look.
https://www.painlessperformance.com/wc/30815
Unless you're running a higher wattage incandescent bulb than the factory 55 watt size you are unlikely to see any benefit to an aftermarket relay controlled wiring harness if your wiring is in good condition.
If you install LED headlights there's absolutely no need for such a wiring harness since they draw substantially less power than the factory incandescent bulbs do.
[URL][URL]https://www.painlessperformance.com/wc/30815[/URL][/URL]
toyota headlight conversion is a good and relatively cheap option unless led headlights are your thing. really like the toyota quality of mine.
Is there a thread on this Toyota conversion?
