What is the best winch for my Jeep Wrangler TJ?
Chris
Administrator
Staff Member
Gillette, WY
This question comes up all the time, seriously. That being said, it was time to make this an official "FAQ".
We're constantly seeing people post topics about which winch they should get. First and foremost, let me say that when it comes to winches, Warn is the undisputed king. They've been around longer than anyone else, most of their winches are made in the USA, they have a fantastic warranty, great customer service, etc. You won't find a brand out there that has the stellar reputation that Warn winches do.
You'll find a lot of Warn winches on vehicles that have been in use for over 20+ years and still going strong. Most of these winches see extreme climates (salty air, rust, extreme heat) and daily use, but still continue to function without a hitch.
What is the best Warn winch for my Jeep Wrangler TJ?
I have no problem sticking to my claim that the Warn M8000-S (synthetic version) is the best winch you can get for your TJ, hands down. Yes, Warn makes higher end winches out there with higher tow ratings, but you don't need those for a small vehicle like the TJ. In addition to that, while there are higher end (and more expensive) Warn winches, the M8000 happens to be the most popular choice for Jeep Wranglers, and therefore is the most tried and tested.
Find any Jeep Wrangler owner out there, and I'd be willing to bet there's a high probability that the winch they are running is a Warn M8000 and absolutely love it.
The Warn VR8 is made in China, but being that it carries the Warn name, you can be sure that it is backed up by Warn's fantastic customer service and support. That being said, if a Warn M8000 isn't in the cards, the Warn VR8 is a great option.
Are there other, more affordable options?
Of course. Other extremely popular options are as follows:
The one thing all of these lower price point winches have in common is that they're made in China. That's not to say they are garbage, because I'm sure that they'll get the job done. My issue comes with the fact that no one can personally attest for the quality control of these Chinese winches. In addition to that, many of these winches only get used once in a blue moon. Sure, that's enough to say your winch works, but unless you use your winch on a daily basis (like a lot of guys do with these Warn winches), then I don't trust it.
For me personally, it's worth spending the extra money to get something as tried and tested as the Warn M8000. I'm not trying to tell anyone how to spend their money, I'm simply trying to explain why it is that Warn can charge more than some of these lower end Chinese companies. I'm also saying that there is no doubt that these cheap winches will work. The question is, will they work when you need them to? You know, after hundreds or thousands of uses, exposure to extreme weather, etc.
It's something to think about, that's all!
What weight rating should my winch be?
The general rule of thumb is that whatever winch you purchase should be able to pull around two times the weight of the vehicle. It doesn't matter if it's slightly under or slightly over, as long as it's close enough. That being said, for our Jeep Wrangler TJs, 8000 lbs. is what most people run, and what I suggest as well. Anything over 8000 lbs. is fine, it's just not necessary by any means.
Synthetic Line vs. Steel Line
The following quote was taken from Blaine, one of the most knowledgable guys out there when it comes to our TJs and off-roading in general.
"Both lines store energy when stretched and that energy is released when the line parts under load. The difference is the weight and the simple way to understand it is you and your buddy each grab a 4 foot long piece of synthetic and the same in steel. Stand about 4 feet apart and take turns whipping each other and see who can inflict the most damage. I guarantee you the guy getting hit with the steel cable will run first.
The advantages of synthetic outweigh every aspect of steel except cost. We wheel some waterfalls in JV that you need a safety tether on. The ability to stand at the bottom of a 10 foot tall waterfall, unspool 20 feet of line and hand toss the whole mess up to the top is priceless.
The ability to spool on a same diameter line that is well over double the breaking strength of the same size steel at 1/5 the weight has some excellent value.
The ability to recombine and repair a broken or damaged line in the field with a simple buried tail splice is not to be sneezed at.
The extra strength alone is enough for me to switch even if it means I have to be just a tiny bit more aware of my rigging practices.
As for the maintenance of steel cable, it is most assuredly not maintenance free. If you do a bit of research, you'll discover that it needs to be cleaned, oiled, inspected for kinks, flat spots, bird's nesting, broken wires, and replaced if any evidence of those exist. The main reason folks think it is maintenance free is because they don't do any, not because it isn't required.
Synthetic isn't for everyone, but those of us who have been using it for a long time, wish it was. I switched in 2000 and at no point have I ever considered going back to steel for any reason."
In conclusion, it's safe to say that the majority of us are switching to synthetic these days. While steel winch line has been in use longer than synthetic, the benefits of synthetic far outweigh that of steel. Remember though, if you purchase a winch with steel line, you can always purchase a synthetic line down the road. In other words, you don't need a whole new winch to run synthetic line, it's nothing more than changing out the line from steel to synthetic.
Conclusion
Buy what you can afford, but if you want something that has been tried and tested for decades, the Warn M8000 as the pinnacle of winches for our Jeep Wrangler TJs. If you can afford it... buy it!
Good to hear as i have the Warn M8000.
Some could say it's my "opinion", but I think it's more than that. The general consensus really seems to be that the Warn M8000 is the best winch (in terms of price, bang-for-the-buck, and reliability) for our TJs.
There's cheaper options, but none of them have the reputation and history of the Warn M8000.
@Chris , what about also listing what else is needed, eg., winch plate, any cabling, etc.
Personally, I am looking at the Engo for my usage. From what I have read in regards to the over seas winches, it comes out very well.
Good point. I will edit my original post for sure.
@Chris, what else might be needed with a winch? Like what winch plates do you recommend? Anything else?
And if I can't afford it?
I agree with everything you said, but....I guess what I'm trying to imply is what if we can't shell out the almost $600 for your top pick?
What would be the best crappy winch that would say...pull me out of a pot hole in the mall parking lot?
I like the Superwinch 9500SR for $480 (w/synthetic rope)
If I were a cheap bastard (And I am), I'd go Engo with steel cable (no offence to cheap bastards, or you Rob). If it wasn't for my wife getting me the Warn M8000 for my birthday many moons ago (god I lover her!), I'd probably have an Engo E9000 on my POS.
Reactions: StG58 and Rob5589
For another $100 you could have a Warn M8000. Yeah, no synthetic rope, but nothing wrong with steel if you use it wisely and safely.
Any of these:
Those are all tried and tested. I'd probably go with the Egno 77-09000S first and foremost.
I'm not even saying any of these are bad winches. My original post is mostly focusing on the fact that some of these others haven't been put through the hell that the Warn winches have, and lived to see the other side. For all I know, they may as well last just as long as the Warn! Warn is selling it's winches based on their name, their heritage, and their durability. That's not a bad thing though!
Reactions: tman66
It depends. If you have an aftermarket front bumper, it most likely has a winch mounting plate built in. If you are using the stock bumper you'll need a winch mounting plate. When I was using my stock front bumper with the winch, I was using the Smittybilt winch mounting plate.
Sure, it's Smittybilt, but all of these winch mounting plates look the same, and they're just to mount the winch on, so you don't need to break the bank for something this simple.
In addition to that, the other thing I have is the Warn Medium Duty Winching Kit. It's a bit pricey (because it's the Warn name), but I bought it because it included everything I needed to go along with the winch, in a handy bag to carry it in. You could piece the stuff together separately and probably come out a bit cheaper, but I liked that this had all the accessories I needed, and it was ready to go.
Reactions: tman66
Thank You, Chris.
No problem! I'm not trashing any of those other winches by any means. A ton of people use the and have never had a single issue at all. The Warn M8000 just has that history behind it, that's all.
Reactions: tman66
I have no doubt that Warn is one of the best there is, however not everyone (including myself) see the need to drop $585 on something that you will more than likely seldom use. For most weekend wheelers out there some of the cheaper options fit the bill just perfect. I'm currently running Quadratec's Q9000 winch and it's been reliable the past three years I've needed it (and I've needed it a LOT). At $300 it's pretty hard to beat.
I'm not a Quadratec shill in the least as I've had issues with them in the past but they've definitely put together a quality product that myself and others can attest to in this case.
I will add that if I was going to be using my winch more frequently (i.e. more than a few times in a weekend) I'd probably invest in a Warn winch just because of their outstanding reputation for reliability. However for everyone else my recommendation still stands for Quadratec's.
Hi everyone, decided to step in, as now I am about to buy a winch for my JK and did a small research, and that's how I found your folks forum. Anyways, the very first post in this topic helped me a lot, especially about Warn winches... yet there is one more winch that I considered as an option, Havocs. What do you folks think of this one?...
I don't see a link.
Here's a Havoc winch on Amazon:
https://www.amazon.com/dp/B01AABYA40/?tag=wranglerorg-20
I've never heard of the brand until now. It has 2 reviews, but it seems new to the market. At that point, I'd just get the Smittybilt 97495 XRC (9500 lbs.), which seems to have a lot of positive reviews, and it's priced well too.
Reactions: DeSoul
I don't see a link.
Oops, seems like I forgot to add it haha
Now, I also haven't heared of them, but I saw a cool Wrangler online last night and it said HAVOC on it, and on the winch as well. And since that's going to be the first serious winch (I'm not counting that chineese winch off amazon that burnt out a week after I bought it).
And here is that link to more pics of this guy - https://www.carid.com/gallery/jeep/...fuel-off-road-rims-wrapped-with-37-tires.html
Thanks, I will check out this one, man. Cheers.
So if I was to swap out my wire line to a synthetic rope, what brand would you go with? Do you match the LB rating to your winch. If I have a 8000lb winch to I replace the wire with a 8000lb rated synthetic rope?
