Used an old set of rear flares to make a template, then drilled the holes. Everything lined up perfectly and I didn't have to remove the armor!
How do you not know the difference between the front and rear flares?
Not sure what I'm missing here?
You don't have to mark the rear flares as rear since they can't possibly work or get mixed up with the front. That only leaves two choices, right or left.
It wasn't to identify front or rear. It was more about easily distinguishing left from right.
Used an old set ofrearflares to make a template, then drilled the holes. Everything lined up perfectly and I didn't have to remove the armor!
BMB tie rod showed up today. This thing is serious business. Even the packaging is tuffness!
Finished my flare install on the armor. And, my tie rod end came in, so the BMB tie rod can go on!
Looks great, Rich. But, those gaudy plastic taillights are like a zit on a super model’s face.
