I am thinking about Savvy taillights, but want to prioritize my marriage!![]()
You're so far into it now that trying to salvage anything that costs what the lights do is like throwing a deck chair off the Titanic to stop it from sinking.
As long as you use the discount code you can say you saved money.
Yesterday, when cleaning up the brakes from the last wheeling trip, I discovered some excessive movement in the front left tire. The spindle nut on the small hub kit had backed itself out slightly. Fortunately, this is an easy fix. All better now!
Assuming those hub nuts don't have a lock washer you fold over that nut then?
If it wasn't obvious, it is rare that the other side will ever back off. The left side backs off due to the direction the tire turns which is usually the same way that backs off the spindle nuts. The other side would just get tighter and eventually smoke the wheel bearings.
When you say excess movement, do you mean you had runout or your hubs wiggled?
No, they have a thick inner spindle nut with a small pin that sticks outward. That gets torqued to less than 5 ft lbs. The washer with holes in it and a tang for the slot in the spindle threads goes on to line up with one of the holes on the pin. Then the thinner outer spindle nut goes on and gets torqued to 140ish.
