Does A/C actually affect engine performance?
DropTopDon
VA
I've always thought that having the A/C on worsens performance very slightly and decreases MPG's. On my old TJ I could definitely feel the difference in driving with the A/C on and off. In my LJ though it feels relatively the same with the A/C on but I haven't tracked MPG's. So is it true that A/C affects fuel economy or performance or is it just placebo effect?
It's true. A/C takes energy to run, and that energy come from the engine. There's no free lunch.
This applies to most EVERYTHING in the car: headlights, blower motor, radio, etc. They may be too small to really notice but if it takes electricity it takes gas. One exception is heat as that's captured from otherwise wasted energy.
I don't remember how long ago this was but one of the car mag's did a write-up on running with A/C or windows down for cooling and they found that you used less fuel then running with your A/C on and windows rolled up. Now as srimes said there is no free lunch and it takes HP to turn the A/C compressor.
As others have said, it’s true.
In my 2.5, I sometimes switch off the AC for a minute in order to avoid downshifting up hill in traffic.
Yes, A/C takes power to run, as does every other engine driven accessory. Engine Masters covered this with what takes how much power (engine driven cooling fan w/ clutch is like 7-10 hp). I think Myth Busters covered the topic of A/C and MPG and showed that below 45 mph, A/C off and windows down was better for MPG, above 45 windows up and A/C on.
I don't seem to feel it as much with torquier engines but I've definitely had 4 cylinder cars where I could feel the compressor cycling. I once narrowly avoided plunging an MX5 into the Arkansas river once after the cycling of the compressor (which was running due to using the defroster) made enough change in the engine output to break the tiny shred of traction I was tenuously holding onto as I descended an icy hill toward a bridge.
  • Wow
Reactions: Kenneth G Zinis
Which is why swapping to the Tarus fan was popular on the 4 banger YJ & TJ's.
Reactions: BlueC
You should drive my Scion XA 1.5L auto, uphill with the AC on. Your 2.5L is a BEAST! 😬
p.s. But I get 38 mpg with the AC on.🤫 It's my $3,000 solution to Biden.🇺🇸
Was this actually a good idea, and did it help? I'm interested.
I did it on mine when I still had the 4 popper and yes, my butt dyno noticed a difference. You have to get some parts from other cars to make it all work well. But it's been too long since I'd done it, so I don't remember what exactly. It was a heavy-duty relay from a BMW or Volvo I think and a sensor or something else but I'm not sure.
I thought about swapping out my fan, but mostly for the sound. I know I know, it’s a Jeep, but mg find is super loud. I live in CT not somewhere super hot, so I think an electric fan would have enough cooling
I did the same thing with a Civic when a family member wanted to buy a truck. I warned him about future (current now) gas prices, now he wants to buy it back. :LOL:
Good point. On aerodynamic cars the drag loss from windows down at highway speeds is more than the loss from running A/C. At low speeds this switches. No idea how this works on a TJ with its aerodynamics.
Reactions: BlueC and Wildman
Yep, since it's a brick already who knows if it matters. And I had full doors for mine but never used them, so I sold them. Soft top and half doors I'm sure don't help matters either.
Have you driven a JL/JT? Holy moly, that's the loudest fan I've ever heard. and it's electric.
