Its more of a rattle than a ticking. Quite loud
Depending on WHEN the engine was assemble will prove as to wether it MAY be susceptible to this design flaw. Goggle it. There are a ton of write up about this crap put out by jeep- or what the hell ever company they were serving at the time.Oil pump drive assembly.
Its an 04....Whats an OPDA?
Lifter bleed down. Unless it is an 05/06 4.0 liter. Then it MAY be the start of OPDA failure.
Doesn't a Google search show this forums results?No need to Google it, the info you seek is right here on this forum:
What is an OPDA and do I need to change mine?
OPDA is more of a screech than a rattle I thought
Bro it depends on how much damage has been done. Mine did one of each.![]()
So did mine.I just want you to know that it's "normal" and very common for a manual tranny LJ/TJ to rattle @ idle.
Engage the clutch and it goes away, on mine at least. Same for every other TJ/LJ with a manual that I've been in.
