I'm betting that puts a smile on your face. And, an even bigger one once you wheel it!
Heck yeah! I been dreaming of this setup for years now. Finally becoming reality!
Best part is you have learned from the best and done the work with your own hands. Will give a lot of joy on top of seeing the improved performance.
Let me tell you it was quite a bit of work and head scratching, especially for my first time doing it all. I bet the second time would be twice as fast.
All I have left is some little things.
-Hook up and bleed brakes
- fill up the diff
- Wire up another ARB solenoid and switch panel
- have fun
You like those pliers, look at these, I carry a pair by my driver seat makes quick repairs without getting into the tool bag.
https://www.knipex.com/products/pip...wrenchespliers-and-wrench-single-tool/8605150
Done. More pics and thoughts later. Finished half an hour before I have to coach!
Is it drivable yet?
This is one of the reasons I struggle with a TJ vs LJ. Where I wheel, a TJ built like this can run almost every trail. A similar built LJ will have to work much harder, and drag more. Very nicely done!
That's why LJ's should be built bigger
It's kind of difficult to bend them around trees, but rear steer would help!
Thanks Rich! It is certainly starting to look and feel like my dream Jeep.This is one of the reasons I struggle with a TJ vs LJ. Where I wheel, a TJ built like this can run almost every trail. A similar built LJ will have to work much harder, and drag more. Very nicely done!
