A
AdalinesDad
Guest
Here is what I have done thus far:
- Brian
- K&N 33-2114 Air Filter
- Replaced Transfer Case Fluid with Valvoline ATF+4 Synthetic
- NGK ZFR5N Spark Plugs
- Crankcase Breather Hose Mopar 53030615
- Clean/Adjust Rear Brakes and Parking Lever
- Replaced Hood Latches with Crown Auto 13104-32
- Replaced weeping radiator with Mopar 55037652AA Radiator
- Proactively replaced water pump with Mopar 68382492AA
- Proactively replaced belt tensioner with Mopar 4854089AB
- Proactively replaced idler pulley with Mopar 4854092AC
- Proactively replaced serpentine belt with Mopar 53013209AC
- Proactively replaced heater hoses with Gates Premium 19038 & 19039
- Trucklite 27270C LED Headlights
- Detroit Truetrac LSD front in Dana 30 with chromoly axle shafts & Spicer U-Joints at the same time (4.10 Gears?)
- Detroit Truetrac LSD rear in Dana 35 with chromoly axle shafts & Spicer U-Joints at the same time
- Replace awful Kenwood radio with a restored factory radio from 1FactoryRadio, possibly with bluetooth
- Mild 2" lift so I can get the max suspension travel out of the 31x10.5R15 that the PO put on there (I like that size and would like to stick with it) NEED OPINIONS ON THE KIT
- New Shocks (Bilstein? Rancho? Teraflex 9500?)
- Teraflex SYE
- 20" Rear Driveshaft
- Metalcloak Adjustable Control Arms
- JKS Sway-Bar disconnects
- Bosch 4 hole injectors from KSuspension
- BBK 62MM Throttle Body
- Exhaust of some-sort
- Source an OEM hardtop
- A/C Kit from JeepAir
- Quadratec LED rear tailights
- Extreme Terrain LED 3rd Brake Light
- GR8Tops Heavy Duty Hinge Kit
- Teraflex CB antennae bracket
- Rugged Ridge CB bracket
- Midland MXT500 GMRS Radio
- Timken or SKF Hubs
- Centric Rotors
- Black Magic brake pads
- Wix 1515 oil filter
- Rotella T4 oil
- Front bumper that can take a winch (Warn?)
- Winch (Warn or Badlands)
- New tires soon before I leave
- Brian
