Quadratec Winch Premium Winch Plate
BDS
USA
Anyone use this winch plate https://www.quadratec.com/products/92122_2900_07.htm. or something similar you can recommend for mounting on a stock bumper? I have the Mopar “Stubby” end caps and I am satisfied with this setup for the time being. Would like to throw a Warn winch on as my first mod. I would also like to be able to keep my stock recovery hooks as well and on some raised winch plates I have seen on YouTube it’s not always feasible.
FWIW, its possible to use the stock front recovery hooks with most/many raised plates if you have an angle grinder:
Primed, repainted, and bolted back on!
I have used on similar with no problems, I removed it and attached the winch to the bumper I built. It worked fine with no problems.
Do you have the bumperettes on front of your stock bumper? Reason I ask is that winch plate is designed to hang over the front of the stock bumper and then it’s cut back to go around the bumperettes (blue below). Without them it may look a little odd.
I posses them but they aren’t on their currently . I like how it looks better without. So it sounds like I should just go with a raised one to get it back over the sway bar and out of the way. Anything wrong with the smittybilt one or is there a more preferable brand that allows use of stock recovery hooks?
Any reason why you can't just flip them to the opposite side?
The hook ends up in the stock fog light territory if you switch them side for side...
Without fog lights in the stock location switching hooks around is a quick solution for winch plate interference, usually…
I have that exact plate. It has held up very well for about 10 years now.
It's actually the 2nd winch plate I've owned. The first one I believe came from Harbor Freight about 15 years ago. The powder coating started peeling off after only a year or so. It was awful. This one has been great!
I still use the stock bumper (chopped down to my liking) without the rubber bumperettes. I think it looks fine, but you can judge for yourself.
That quadratech on will work fine if you’re ok with the winch sticking out some.
I have a smittybilt raised winch plate and with an aftermarket bumper and roller fairlead, it still stuck out some. I never had it on the OEM bumper though, so I don’t know about that.
I currently have Blaine’s ST fairlead and it’s slightly back from my bumper now.
Also, some Curt tow hooks are slim, cheap and fit perfectly in the OEM spot.
CURT 22411 Bolt-On Black Steel Tow Hook with Spring Clip, 10,000 lbs Capacity https://www.amazon.com/dp/B001GMZRQ8/?tag=wranglerorg-20
With roller fairlead.
With ST fairlead
Reactions: Irun and DrDmoney
I think mine is a rough county plate. Its on a stock bumper and still utilizes the tow hooks with the ability to use a stock sway bar. I think I paid $50 for it but that was also a number of years ago.
Can you get a flat winch plate that's not drilled or cutout for the bumperettes?
I'd like to keep my factory bumper and be able to push the winch plate back farther since I no longer have the stock swaybar.
If I'm understanding your question correctly, I believe you would either need a plate that sticks out a bit or you would need a raised plate on the factory bumper. This is because the bolts to mount the winch to the plate would interfere with the bumper, otherwise. I don't think you could have a flat (non-raised) plate on the factory bumper that doesn't stick out a bit.
Someone please correct me if I'm wrong.
Notice the 2 front winch mounting bolts in these pictures just above the license plate. This plate can't slide further back because they would interfere with the bumper.
I was thinking you could move it back far enough for those to be behind the bumper.
Maybe that puts the winch into the grill.
Worse case; you could notch the bumper, use countersunk bolts, or some other work around.
