yes its possible.But do you think water is in the transfer case also? I assume someone drove this Jeep through deep water.
You need to check everything. Trans,tcase,and axles
View attachment 384437Is that the right plate? Just above the skid plate. Magnet DOES stick to it.
Nope. That's the transmission mount.
Generally water gains easy entry into the trans thru the shift tower but the TC case not so much, but no reason not to change the trans fluid now. How were the diff's.
I haven’t noticed any problems. What would the symptom be?
Got it
I’ll have to check today.
I put SAE 10w30 in the transmission. How long should I run it before putting in new fluid?
Also, the water contaminated fluid was like pancake batter to clean up! I literally had to use a kitchen spatula to clean out my catch pans! Messy messy!
As i already said,you need to check everything. You bought a used vehicle of unknown servìce history and known lack of proper maintenance. Change every fluid,including brake fluid. And all filters. Brake,suspension and steering inspection.get to know your new jeep.
