$56.99 at Quadratec with free shipping. And that's only the first place I've looked. That's encouraging...
I gotta get down under one day. Sitting on the beach, in front of a campfire, drinking beers with you, and listening to your crazy tales.........priceless!!!
haha that would be great...I can see me having to get one of them there minivans or a 7 seater stretched TJ to haul around everyone who wants to come down here. lol
Parts are in. Ready for a Rust filled NE Jeep disassembly
Lot of rust especially on the 3 12pt bolts that hold the hub assembly. One was round without even touching it with a wrench. But with patience and heat all but one came out. The one that didn’t I hammered an extractor socket on, heated it, and it broke loose
U joints in the box along with the ball joints will be on here soon
I’m gonna clean all the rust up and repaint Anyone recommend a process and product for cleaning and painting??
Decided to order new Hub Bearings, DEFINITELY, new bolts! And new disk brake shields
yeah those are done! Morris 4x4 has new replacements.
Ball joints are ready to be pressed out.....to be continued :)
Isn't it fun working on vehicles in the rust belt? Good Job. As far as refinishing the knuckles, If you have them off, you might sandblast them if you have the means to do so. Otherwise a wire wheel and a good stiff wire brush are going to be about the best you can do. Get some Truck and Tractor paint and a can of hardener from your favorite farm supply store. Brush that stuff on, and you'll be golden.
So much fun! All in all tho, this went way better than the rear shocks when I lifted it. That was a pain in the A$$. Bolt snapped off in the tightest of spaces, luckily I had two experienced friends doing most of the work. They had to drill right thru the old bolt in the end but they got it. I purchased a big jug of anti seize just in case I ever need to come back in 50k miles
Old...
New...
View attachment 28842 View attachment 28843 View attachment 28844
Installed the MC bumper/tire carrier today. I know/feel this is over priced but they do make quality stuff. I really like the design of the dual mount tapered roller bearing. It lowered the spare so I have a little more rear viewing while driving.
That tire looks huge!! What size are you running?
Bumper looks awesome!!
2005 RHD TJ Sport
2010 BMW 528xi
Its similar to the one @CodaMan posted. Here is the link to the one I bought.
https://www.amazon.com/gp/product/B06XCH8155/?tag=wranglerorg-20
Its a bit cheaper, and thicker steel. The EAG one is 5/32 while the one I bought is 3/16...I'll measure it when I get it, as there is only about 0.0325" between 5/32 and 3/16. It will be interesting to see if it really is 3/16.
That's an even better price, but I would assume they're all made in the same Chinese factory with just a different name on them.
Today I made some inserts for my D-rings where I attach my tow system for the Motorhome. 1-1/2 square 6061-T6 milled down to fit D-ring and receivers. Need some? Dang rain started after my final coat and messed up the paint. So I will repaint this weekend. Have to Love Washington weather!! Hit me up in a PM If you want some.
Today I made some inserts for my D-rings where I attach my tow system for the Motorhome. 1-1/2 square 6061-T6 milled down to fit D-ring and receivers. Need some? Dang rain started after my final coat and messed up the paint. So I will repaint this weekend. Have to Love Washington weather!! Hit me up in a PM If you want some.View attachment 29110 View attachment 29111
Nifty idea! I have the same tow bar mounts. if my bumper didn't already have D-ring mounts, I would hit you up for a pair.
Reactions: ac_ and Marc L
Got the new ball joints in
used the ball joint press to remove old beat u joints. One cap had zero needle bearings and was just rust!
A little polish and rust prevention
my new best friends delivered again lol
only screw up so far...I broke a cap trying to put u joint in with the press. Bought a new one and used the “gentle hammer” technique
coming together nicely, new disk brake shields should arrive today and I can call this done!! Anyone got a torque wrench that goes to 175 ft lbs I can borrow lol
