Commies
Yes. Very blue state. Fuckin Detroit
Commies
I have this heater in my garage, but it runs on propane. I typically only heat my garage when I have projects going on. When it's below freezing outside, I turn the heat on in my garage and only have to wait about 10 minutes before it's comfortable. My garage is insulated, but only R19 walls and ceiling.If he's in town, a NG heater is pretty inexpensive to install and to run. That's what I use...65000 BTU and I only bumped my gas bill by 30/40 dollars a month...and I'm heating a 24 x 30 two story barn with it.
as an example
Mine draws combustion air from outside too, so I don't have to worry about a big ka-boom! when I'm making fumes or doing anything that releases a lot of fine dust.
I use a propane cannon style heater. 10 minutes in my 2 car and I'm in a t-shirt. Only have to run it for a few minutes every hour or so to maintain.
Is what you use something like this?
Mr. Heater 125,000 BTU Forced Air Propane Heater F271390 https://www.amazon.com/dp/B00KRFVG5G/?tag=wranglerorg-20
How many BTU’s would I need for a normal 2-car garage with 8-ft ceilings? 35,000? 60,000? 125,000?
I only heat the garage for intermittent use.
Depends on your climate zone...
For warm climates (climate zone 1-2), most HVAC people suggest 20 BTUs per square foot. In colder climates, say climate zone 4-5, most suggest ~50 BTUs per square foot. In super cold places, climate zone 6+, it can be up to 70 BTUs per square foot.
Are those numbers based on interior? Cause if you need a garage heater in zones 1 and 2 you might be a weenie.
I live in zone 3 , in the winter I have to go from flip flops to shoes and socks!
also Zone 3 here (OKC's avg daily low in January is 29 and high is 50), with an insulated garage I do ok without a heater just wearing some thermals under my jeans and my Dickie's long sleeve work shirt on the coldest days. I also use a rolling creeper so I'm off the floor, and my garage work is all hobby so if we get an uncharacteristic cold snap, I can just take a day off. I'd probably want some heat for occupational use where I was in there daily, especially if I was moving vehicles in and out through an open door.
Now, when I was building my LJ in the evenings through a Zone 5 (17-40° average January) winter in an uninsulated garage is when I got the Big Buddy and an adapter to attach it to the tank I use for my grill. I set it up facing the area I was working in but far enough that I wouldn't bump into it, and I'd usually end up turning it off after an hour.
Anyone a fan of a waste oil heater? They seem to have a bit of a price tag, but if you don’t have natural gas are they worth it? Or is it easier to just jump off the kitchen and laundry propane tank and go gas.
