That's my DIY Spod solution and more.
You have some skills! Does that slip into the stereo opening or mount somewhere else?
Howdy everyone. I searched for this topic but came up empty! I'm a newly minted ham and wondering what the hams on the forum are using for radios, antennas etc. in their TJs. Thanks!
It's like all hobbies, theres good people and bad. Unfortunately the bad ones tend to be a lot louder than the good ones.
The contacts I've had over the air have all been pretty good - but VHF/UHF is pretty dead around here for the most part. There are a couple of nets that I've participated in a time or two - but they're on dance nites so I don't get on them often enough. I really, REALLY want/need to break into HF - that's where the "real ham radio" is to my way of thinking. In any event, it doesn't rely on an active local scene.Most of them are actually very helpful, but there are always a few bad apples in the barrel. I considered doing the mod to my Ham radio, but decided to keep it true and just add a GMRS radio and keep them separate. There is room if you keep it simple.
I run a pretty basic Yaesu FT-2900r 2 meter rig and it works fine for my offroad needs. I had a dual-bander at first but since I never needed or used its 440 MHz abilities when I needed a replacement for my current TJ I stayed with a less costly 2 meter only radio.
It's mounted on an Arizona Rocky Road mount which requires no drilling and hides the cabling inside it. I wrap the mic cords around the mounting bracket when I'm not using it. That's a Uniden CB bolted to the bottom of the Yaesu.
N4TAY is my call sign, yes I changed it from N6TAY to N4TAY after moving to Florida. I'm trying to eliminate my California past.
I don't blame you - I went to the tax collector's office the day after I arrived here to get rid of my Commiefornia plates!I'm trying to eliminate my California past.
VHF is used here quite extensively. The RR channels (Resource Road) and the call protocol are posted at the start of the road in question. Much mining and logging road, with off-road/wide trucks and equipment. Safety factor/pucker factor.. . . . but VHF/UHF is pretty dead around here for the most part.
The other radio you see in the first pic that at the bottom of the dash is my GMRS mobile.
I have my Ham antenna on a tail light bracket and my GMRS antenna on a A-pillar mount.
The Ham antenna is a Diamond. I don't recall the model, but is a dual band. The GMRS antenna is a Midland.
Edit: congrats on getting your Ham ticket!
If I may ask, where did you find the A-pillar antenna mount?
Thanks again everyone for all your comments.My girlfriend just got an Icom 5100 for her rig. I'm still researching!
SSTJ, thanks for the search engine advice, it showed lots more results!
bobthetj03, I also would like to know about the A-pillar antenna mount.
Sorry to hear that some of you have had a bad experience with your local hams. I'm very happy to report the opposite experience here with our local folks. They've been absolutely supportive, informative and friendly. Maybe we're just lucky but everyone has been great so far. I'm studying for my Extra and hopefully will test here in a couple of weeks. I'm also working on getting a shack set up as I would like to work in HF as well. Thanks again everyone, KD9WBN
X2, there are plenty of TJ owning assholes too.It's like all hobbies, theres good people and bad. Unfortunately the bad ones tend to be a lot louder than the good ones.
I got my license through the Ham Cram sessions that was put on by the Stockton Amateurs.
Study, take test and get your ticket in one day. Just have to wait until FCC posts it.
Some don't go above Tech since it gives you access to you local VHF/UHF bands.
http://www.w6sf.org/hamcramsignup.html
Got my Tech in 2012 and upgraded to General in 2019 so I could get access to some HF bands with my old Icom 756pro.
I've been into radio since the 70's with then CB. even had a CB license. It was the code I could not get through.
I wished more in my club would embrace the 2m band since we have all sorts of repeaters in our area, even on the Rubicon.
I can see Mt Diablo from my house, so should not be a problem.
Mt Vaca I'm not sure?
