Reverse light LED
Kiwi TJ
I don't suffer from insanity I enjoy every minute
Auckland New Zealand
We all know about how the 'illuminating' the rear reverse light is on TJ's.;)... I came across a low budget replacement option, probably been done before but couldn't find a thread,anyway ....I replaced the standard bulb with a bayonet fitting LED. Massive difference and a quick ,cheap and easy mod.
Looks good! I've got LED read taillights, and I always look forward to putting it into reverse at night. It's so bright it just lights everything up behind you!
Yowza! OK, @Kiwi TJ , what am I looking for? What is this bayonet mount LED you speak of, and where did you get it?
OK, just searched this and came up with about a zillion 1156 LED bulbs. Cheap too! This is pure genius!
Genius for sure.. lol basically it looks like the old bulb we know and love but has an LED inside instead of the filament... simple plug and play but with sooooooo much more light... did the same with my rear lights as well, instead of a white LED I got red ones... now people can see me from behind.
Right, so I was in town today and picked up a pair of Sylvania ZEVO 1156's for the back up lights. According to Sylvania they are supposed to be "superbright". They are brighter and whiter than stock, but we'll have to see how bright I was popping $25 on them. I forgot that the TJ backup light doesn't have a reflector in it, so half the light generated is wasted in the taillight assembly. Now the search is on for a reflector that will fit in there.
Thanks again, @Kiwi TJ , for the tip on this. Woulda never thought of that on my own.
No worries @StG58 all part of the service... let me know how they look.(you may not even need a reflector as they are pretty bright)
Old school the reflector by putting an small convex mirror, they have tape on the back. Helps a little and they are cheap.
Yes I’m replying to a 7 year old thread…
@StG58 any pics of how the Zevo LED’s are in your reverse lights?
If the ones you are looking at or what I’m thinking they really don’t project well-
These do- Notice the end is a bulb also-
Not sure if he is making them anymore due to supply but @Claytone makes a hell of a reverse light
I bought a set of those LED reverse lights when @Claytone posted them For Sale early last year....
They are a projector style LED with a heat sink incorporated.
Prior to installing the LEDs I installed strips of aluminum air conditioning ducting tape (similar to Zorba) inside the tail light housing for both the parking/brake lights and the reverse lights; the increase in usable lumens is quite noticeable.
For those of you that just put an LED into the reverse lights and lined the housing with foil tape, did you line the whole thing (of the upper reverse light section) or is there a “strategy” to tape placement as far as reflecting light the best?
Or is this about all you did?
