I recently installed the OME 4” lift coil springs. They ended up giving me at least 5” of suspension lift over stock. I’d like to add a 1.25” body lift as well, but would that be a bit too high and unstable? Should I just stick with the 5” suspension lift and no body lift? The tires clear the fenders either way on full compression, so clearance is no issue. Thanks.
