My transmission goes into overdrive & lockup around 42 mph which drops my RPMs to about 1600.
I read that lugging your engine is bad for a turbo, but I'm not sure how that rule plays into in-town driving where load varies.
Should I drive with OD off for in-town driving? At 45 mph, the RPMs are at 1627 (OD on) or 2358 (OD off). It seems that I could keep OD off until I approach around 55mph.
I'll likely be in boost more often if I have OD off in town. I don't have enough experience to know if that's good, bad, or doesn't matter. The Banks turbo is set to 6 psi of boost.
Here's a visual from Grimm Jeeper showing the engine RPMs when in 3rd versus 4th gear at different speeds.
