Well try going a touch deeper and see what happens.
TWSS
Your coast side is definitely in the zone I just wish your drive side had the same look. Try adding another drop of oil to the marking compound and really put some drag on the ring gear and see if we can get a better look at that drive side.
This is your front 30 you are working on now? Those show your coast side (drive side of a LP front) a tiny bit deep. For a front that would probably run just fine but if you can pull .001 it would be better.
No sir , this is the 35.
Ok well I would definitely try to pull .001 if your shims allow and I think that will be as good as that set of gears is going to give.
I agree, 1 thou should do it.
10-4. I’ll make it happen and report back. I wanted to say also that I really do appreciate y’all taking the time to be a second and third set of eyes.
Yes on the loctite. If they say 150, then go 150. Most shimmed pinions give a range of 160-210.
Pattern looks great!. Nice work sticking with it.
