There are enough take outs for sale that one may wonder why there are so many.
@mrblaine have you seen folks have trouble wheeling with JK/JL swaps? I'm sure there are enough guys in your area looking to save some monies vs. going curry axles..
Love your rig man! That is scary close to how I would like to set mine up. How's it do on city/highway with that setup?
I have seen issues. I won't build another JK front axle if that tells you anything. Also, be aware that there is more than one width JL axle. If I couldn't get them out of a Rubicon, I'd pass. I think it is the Willy's edition that is a stand alone axle size so watch out for that.
What wheelbase are you shooting for?
Then you can get yourself some rimz.
My questions are:
1. Does anyone have direct experience with an axle swap like this? How much of a PITA was it to build everything the right way, minimizing bump steer/flexsteer etc?
2. Has anyone done a JL/JT axle swap specifically? They're way beefier than JK axles, but no one offers a swap truss kit for JL axles into TJ as of yet.
3. How bad are the 37s with 5.38s and 4.0 as a daily driver?
So let me know whether this is reasonable or if I'm talking out of my rear end . Thanks in advance!
I most certainly will NOT try to talk you out of 37s, misery loves company
My biggest complaint by far with 37s is driving on the highway. I have 5.13's (i will be changing eventually to 5.38) and the 42RLE just BOGS going up hills at highway speeds. It's do-able dont get me wrong, but I would LOVE a modern transmission where i could hold gears and doesn't suffer from the .69 OD of the 42RLE.
Yes i have direct JK swap experience. It was WAY over my skill level when i started but Blaine's guidance and Toximus's write-up on coilover swap made it approachable. Anyone can do it, and I'd be more than happy to help you out some. You can see my build if you want all the dirty details, it's pretty in depth. Here's the first post of the coilover swap: https://wranglertjforum.com/threads...e-the-3-rs-of-a-first-build.30419/post-505248. That being said i'm going to swap the front JK for a fabricated axle eventually because i want 60 outers with big balljoints, wheel bearings, and selected hubs ... and racer style. I'd be happy to go for a walker valley wheel and show you how the jeep works, its basically what you've spec'd except 5.13 gears.
The weakpoint for me on JK axles are the balljoints. I have a set of balljoint deletes waiting to go in, might start those on Sunday actually. I have like 8000 miles on the Smart Parts "Load SHaring BJs" some pretty hard wheeling with hydro assist on them and i think they're going out.
For a rear axle I went the ECGS 489 with 35 spline and have had zero issues. I would like to swap it only for a high pinion for better rock clearance in the future.
Most Jeeps share outter and inner Cs between 30s and 44s. If I recall correctly a Jeep 44 isn't a "true" 44 as much as it's a 30 with a 44 diff.
I'd either beef up your existing axles...I sleeved and trussed my 30 but I'm on 33s and planning for 35s (and dreaming of 37s). That was as much an experiment for the experience as much as anything.
Personally if I was going for 37s and could afford it...I'd do a wheelbase stretch and dual 60s with rear steer.
Since I can't afford it I'd throw some trusses and sleeves and braces at your existing axles, throw on 37s and send it.
One good thing about 30s and 44s is weight and smaller housings mean more up travel!
Full send is the only way.
Seriously tho, I wonder what would fail first with 37s on a HP30/Dana 44 combo. Probably shafts, which you could swap in some RCVs. Then what? Driveshaft ujoint or ring and pinion I would think. Ball joints would lretty much be a consumable.
Definitely not a good idea anyway you look at it.
