Bump Stops
Rex2022
Lifetime Supporting Member
Peoria, AZ
my ride: 2003 TJ, 4.0, NV3550 (manual), 3.5" inch lift
My TJ's bump stops are falling apart and I would like to install new ones. Which ones do you guys recommend? I don't need anything fancy, just good quality bump stops. BTW, I have a 3.5" lift if that matters.
Thank you!
Thank you!
Are your bump stops cracking or are the jounce bumpers falling apart? If it's just the jounce bumpers Crown are decent.
For the bump stops there are several good options. Just avoid anything that replaces the jounce bumper with a longer poly bumper. I believe I have set if Rubicon Express on the front and I just ordered some aluminum pucks of Ebay for the rear.
It's the jounce bumpers (didn't know they were called that).
I'm assuming the front and the rear are the same jounce bumps, right? No separate part numbers?
Edit: I found out they are the same part for both front and rear.
Thanks to all that responded. I ordered four Omix brand bumps.
Reactions: 06lj
