The other day Overland Outfitters sent me a box of samples to test - a line of weather-resistant storage products they plan to release in the spring. In this photo: Tactical Spare Cover, SpareHopper bag, 6" and 12" weather-resistant MOLLE bags, a SpareSide bag and a MOLLEWrap for the spare. Also at the right side middle is a Gladiator Bed Bag but that's off-topic for this forum so I won't include it in this post. These are preproduction samples, so they don't have final production hardware and some of the details aren't final yet but they're close enough for testing and for me to provide them with feedback.
I've been using a preproduction SpareHopper bag from them on my LJ for several months now because they wanted it tested through the NY winter. It was on my LJ when I drove it from upstate NY to Las Vegas for the SEMA Show a few months ago, in this photo it's pictured at end of a trail to the bottom of the Grand Canyon. It's been on the Jeep all winter and there have been no problems with the weather.
The SpareHopper in the photo above is olive drab but they tell me the first production run of all of the products will be in black. This next photo is a preproduction SpareHopper in black. Don't mind the salty LJ, it serves plow duty all winter and doesn't get washed until the plow comes off in the spring.
I've been testing this bag with a lot of weight, in this video it's on my JKU and carrying a cinder block (42 lbs) and 2 gallons of milk (8.6 lbs. each):
Carrying that much weight in a SpareHopper is a good argument for installing a tailgate reinforcement like the MORryde/Gr8Tops
I use the SpareHopper all the time - in NY State stores aren't allowed to put your purchases in bags anymore so I carry my reusable shipping bags in there because there's no good place to keep them in the Jeep. And when I'm on long trips or offroad expeditions I use it for a trash and recycling bag, it's just the right size for a standard kitchen trash bag to fit inside.
It's easy to move the SpareHopper between the two Jeeps because the mounting straps are separate and the bag attaches to the straps with clips. I've got mounting straps on the LJ and the JKU so I can use the bag on either one.
Next up is the Tactical Spare Cover. It's got MOLLE grids on both sides and on the face, and also a pocket inside the face.
In this next photo my Tree Saver strap is sitting partially out of the pocket, it does fit all the way in.
To go with the Tactical Spare Cover (or any other place where MOLLE is exposed to the weather, there are 6" and 12" weather resistant MOLLE bags. Here are a few on the spare cover:
And for more storage, similar to the SpareHopper but in a smaller size, are the SpareSide bags. They attach to the MOLLE on the side of the spare cover.
On the TJ/LJ the spare is a bit towards the passenger side of the Jeep so a SpareSide bag can interfere with the tail light on that side. The JK is wide enough for a SpareSide bag on either side, but on the TJ/LJ it's probably best to use a SpareSide bag only on the driver's side and put a weather-resistant MOLLE bag on the passenger side.
The SpareSide bags or the MOLLE bags can also be used without the spare tire cover - the MOLLEWrap is a band that wraps around the spare and has the same MOLLE grids on the side that the spare cover does.
The MOLLEWrap is also compatible with the SpareHopper, in the next photo I've left the SpareHopper straps in place and installed the MOLLEWrap over them so both the SpareHopper and a pair of molle bags or SpareSide bags can be carried at the same time.
All of these products are made from DWR/UV-treated (durable water resistant) polyester so they'll stand up well to the weather and the sun.
Since they're pretty quick to install, I'll use them on an as-needed basis. I'll keep a SpareHopper on each Jeep all the time for the uses I mentioned above and throw on one or more of the other bags as needed for whatever situation I'm about to go into.
I do have some suggestions for improvements in the details of the products which I'll pass along to them.
They haven't given me an exact release date for any of these other than "soon". I think the first show they're doing this year is Overland West, so these will probably be out before then.
