I wish to flat tow my 05 TJ , but I have front lockers and a positrack rear end. I am new to jeeps and wondering if this would be an issue when towing around curves and corners? Any advice appreciated!
steering wheel lock position ignition to prevent release parking brake.
Just as JKP TJ Addict wrote see belowCan you explain that for me? I am definitely not understanding what is written.
The posi rear end isn't an issue.
A selectable front locker wouldn't be either. Need to fill in your profile details.
“The ignition should be UNLOCKED, (not ON, to prevent battery drain), to prevent the steering wheel lock from engaging on MTs.
Then release parking brake.
MT can be in any gear, but I'd pick one of the upper gears in case the tcase somehow gets out of N.”
Seems I could unlock steering wheel by turning key to first or second click w battery disconnected. I have a battery quick disconnect installed. I want the steering wheel to be able to turn, right?
And next flat tow question is… do you have your TJ brakes linked somehow to pull vehicle brakes or just tow it without? Again, I’m totally new to this and need to tow it about 600 miles.
https://www.a1racing.com/detroit-locker-tractech-912a585-detroit-truetrac---dana-30-27-spline.aspx
This is what I have in front box, ok to flat tow with it?
7. Shut engine off, leave in 3rd gear required to maintain trans lubrication,
