I’ve been working on the GR front fenders and rear corners that
@Alex01 and I installed in Moab. There were several things to fix/finish.
On Saturday night we mounted the driver side fender to the factory inner. We didn’t realize initially how much of the spare battery tray needs to be cut out. If I were starting over I’d literally cut a 2”x3” rectangle out of the corner and be done with that interference. This is because the non-HiLine GR fenders do give you a little more room back than factory fenders. It’s nothing worth bragging about, but it does take a lot of cutting wheel and BFH action to get there. The other thing we didn’t realize was you need to bend the mounting bracket under the battery tray 20* back for those two bolts. Finally, you have to trim a good portion off the hood latch bracket so the fender doesn’t interfere as you push it back so the seam is flush at the firewall.
Of course, to do this the sliders have to come off. On and off a several times and I’ve gotten pretty adept at that! Of course, we didn’t get all that done that night, so we had to improvise. They held up fine during the flop, so no big deal, but now that side is all fixed. The factory fender just needs something to fill some of the gaps due to cutting so you can weaken it enough to beat it back.
We did the passenger side on Monday and it went much easier even though we had to deal with the battery. We got it right the first time, but didn’t have time to mess with the side markers on both sides and I had to fix them when I got home.
