Yep....looks rugged, like a Jeep.
To each their own. I like the fact everyone does what they want to their vehicles as that is what it is all about.
That's the worst look ever.With, and I'll add to this. With a matching Spare (size and wheel). Nothing worse than a good looking TJ or JK rocking 4 nice rims and the stock rim and tire still on the back.
Soooo you think if its too big it may look something like this ...? lolI was thinking about this and I am not sure about the spare on the back of a Wrangler. I think the picture you posted looks right. I don't think a huge 33 or even worse a 35 on the back does however. Mine came with a 33 on the back and I think it looks stupid. It is too big. I am not sure what I am going to do about a spare yet, but I won't have one if I am running 33's I don't think. Here is a picture. View attachment 31812
Thats a good look.I ‘filled’ the holes with little plastic grommets and four torx bolts.
Im with you. Several brands offer tag relocation kits that take up the tailgate area tjat is normally reserved for the spare. But this also deletes the stock tag location and then you will have holes there too...:risas3:Problem with running no spare and no rack is all the open bolt holes that get left behind. Just screams something is missing.
I wasInspired by 2001 space odyssey?
Cool PicIm with you. Several brands offer tag relocation kits that take up the tailgate area tjat is normally reserved for the spare. But this also deletes the stock tag location and then you will have holes there too...:risas3:
https://www.amazon.com/dp/B01H0S8YVQ/?tag=wranglerorg-20
Amazon is now a source for Motobilt parts. FYI
https://www.motobilt.com/jeep-yj-tj-spare-tire-delete-tag-mount.html
what causes the fine lines under the clearcoat???
the clearcoat has failed, allowing the aluminum to start corrodingwhat causes the fine lines under the clearcoat???
