I am currently researching this because it is hot and I have to be efficient at the junkyard. Do I have this right and is there anything I have missed?
Note - I want to do this for ease-of-maintenance reasons, I know there is no performance gain.
I can get parts from a 1995-1998 Grand Cherokee or a 2002-? Jeep Liberty. Looking at both vehicles gives me more choice in the junkyard on picking the best ones.
Need to get:
Check the calipers work and if not use them for the core return when buying new calipers.
Use a cable clamp to attach the existing parking brake cable to the calipers (don't want to crawl under the junkyard vehicles to remove the matching parking brake cable setup). Which clamp would work best? @Dan_Goodwin mentioned doing this but no pictures or further details.
In this post: https://wranglertjforum.com/threads/tj-rear-disc-brake-conversion.8190/post-207319 @RangerRick said:
However in this post: https://wranglertjforum.com/threads/tj-rear-disc-brake-conversion.8190/page-5#post-734950 @Dan_Goodwin makes no mention of the hard lines.
Does this mean that the soft lines from one of these donor vehicles can't be connected to the hard line on my Dana 35? Is there an off-the-shelf adapter? I have made my own flares for brake lines in the past and I don't really want to do it again.
So far I have a total cost, if the junkyard calipers are ok, of $340+tax.
I can knock $100 off that by using junkyard rotors instead of buying new, but I am not sure how to gauge if a particular rotor is OK to be used. I guess calipers to measure the thickness and check for scratches or gouges, but anything else? I presume warp is not visible to the naked eye.
Thanks! Andy
Need to get:
- calipers
- caliper mounting brackets
- four bolts that attach brackets to axle (they are longer than the drum bolts)
- soft brake lines
- bolt that attaches brake line to axle (what is this? any pictures of it?)
possibly grab the hard lines off the ZJ Grand donor axle to re-use on your axle unless you know how to properly cut install & flair brake line fittings safely
Thanks! Andy
