Pull the drain plugs.
That happened to me the first time I took it out without the top
This happens to mine almost every time it rains....parked with a hard top...![]()
You need a bilge pump![]()
I do the same thing, although our choices in music may be slightly different.Last night was "Zombified" and tonight will be "Voices in my head."
Let me know what you think of it when you’ve got time… I’m looking at getting a frameless top… with the new TJ I’ve got a hardtop and no frame for a soft top… I’m thinking the Frameless top might be the best play… those summer night drive are just no the same with a hardtop on…
How about the ones on your Jeep?![]()
Are there any downsides to leaving the drain plugs out permanently?
Can I get a sanity check on my order of operations.
I’m replacing my cracked radiator so I’m taking the opportunity to replace my original waterpump with a new Mopar, at which point, the cooling system will have been entirely replaced.
Should I
1) pull the old, radiator etc, install new pump and radiator and that’s it?
Or
2) use an emergency patch on the radiator, pull the fan, install new pump, assuming the patch holds, I can test for leaks on the new pump and then install the new radiator?
I’d like to avoid rework but don’t want to make the install overly inefficient.
Just picked these up from my local pick n pull.
Currently fabricating a wire harness while my Jeep has its engine replaced. They come heated and fully powered with lumbar support too. I got Everything to work. So I’ll be hooking up flip switches.
