06 TJ Build
joshself
I bought my 06 TJ about a year and a half ago and it has progressed from then. It's a 6 cylinder 4.0l with a 6 spd transmission. I've done what I can with it whenever I have time, so most of the pictures I'll add are past projects and mods and they'll eventually become present.
Picture when I bought it from the PO:
Currently:
I quickly did little changes like removing what chrome I could.
Bezels were made black:
Homemade hi lift mount for $5 with u-bolts:
New bumper and winch:
Reactions: JP13
What did you do?
I'm working on it. :) it's gonna take a while to show all of what I've done. I have a build page on wrangler forum that went in order, but I'm recreating it here.
Sent from my SM-N910V using Tapatalk
Reactions: bostontj
Bedlined the tub:
Homemade accessory fuse block for lights, winch, cb, etc
Mounted CB Antena
Upgraded headlights to KC day lighters:
Reactions: JP13
Dash, gauge cluster, dome and courtesy lights changed to red:
PA mounted for the trail. I don't have to yell out the window now.
Replaced door bushings
Reactions: JP13
I would like to install blue dash lights. How difficult was that to do, and what did it cost you? Nice Jeep man, im diggin' it.
It cost me $15 in the end with all lights. Dash would be about $7. Go on superbrightled.com type in your year of TJ and plug and play. Requires taking the dash off, and if it doesn't light up then the light is in the wrong way. Took 20min.
Reactions: JP13
It took 2 hrs to punch them out with a pick and lots of PB blaster
I can tell. Probably a good idea for most of us to replace the door bushings as they get old and neglected.
Reactions: joshself
Steering box skid
Shot of the blinders
Homemade CB mount on cosole- no drilling
Snapped winchline while wheeling
Added flat fenders
Mounted my Cold Steel shovel on the tailgate:
Seat riser kit, even though I'm 6' it's still nice.
I used Rubicon sliders to cover up the holes from the flare extensions. Over top I added tube sliders
Finally repaired the winch line last week
Now that most of the bigger things I've done are on here, I'm sure I forgot some, I can now talk about what's next.
Hopefully in the next few weeks:
-welding custom front bumper, stubby for better tire approach
-remove previous owner's 2" budget boost and install 3" suspension lift
-JKS quick disconnects
-extended breather lines
-SYE and Tom Woods driveshaft
-Novak Cable shifter
I'm going to slowly beef up all of the harware as well. My bumper hardware is already grade 8, but more needs uprgrading.
