New bluetooth rear axle
Wa ......
Fan runs more than it did before. *shrug*
That would be okay, provided the temp stays lower
Just get up really early to do some work before it gets too hot, like 6 a.m.
Lubed all the fittings, installed oil pan / transmission skid plate, and installed a GMRS radio and antenna today. Full day but productive. For power for the radio I piggybacked off the fuse for the 12 volt power port. Figured the unit came with a plug to plug into it so figured this would be safe, I seldom use the power port anyways. I also tried out the York air compressor for the first time. From 15psi to 35psi in just over a minute, not too bad.
Are you happy with the reception with the antenna mounted there? How did you ground the antenna mount?
At least it says ARB and not ABR![]()
Not today but this weekend:
Finalized installation of cruise control on my daughter's 2004 Wrangler
Installed GMRS radio in my 1998 Wrangler.
Installed rebuilt mopar power steering pump (I rebuilt it with a Gates bearing and seal kit) in my son's 2003 Wrangler.
No photos as I was too busy doing the work.
Is that a Rostra cruise control?
