That looks very good. I wouldn't pull any more, but what I would do is grab each connecting rod on the crank and try very hard to rock it back and forth and up and down. If you find one that moves, you've found your culprit.
Also, as someone said above, try to see the piston skirts while you have the pan down, check em all out. Did you find anything in the oil pan?
How much of the timing chain can you see with the pan down? Good Idea to check that too since you're this far in anyway.
