I've got one last Blitz jerry can tray to get rid of, all the rest have been sold. This one is in excellent condition as you can see in the photo. $25.
The Auxbeam light bar I sold earlier in this thread came back to me. The buyer said it arrived with a broken plug housing, see the photo. It was fine when it shipped out and it was still in the original Auxbeam packaging so I don't know where or how it got broken.
I tested the light bar with my bench power supply; the broken plug still makes a good connection but the locking part of the housing is what's broken. The light bar works great, the broken plug is connected, it's on top of the coiled-up wiring harness:
The test setup:
I was asking $60 for this, it's on Auxbeam's web site for $109.99. In its current condition with the broken plug housing I'll ask $40. Shouldn't be hard to swap the plugs or just hardwire it. If I were going to use it, I'd put a pair of two-conductor SAE plugs on it (like 4-pin trailer connectors, only with 2 pins, there's a pair of SAE connectors in the photo above) and call it good. The details of the light bar on the Auxbeam site:
https://auxbeam.com/collections/led-light-bars-by-series-5d-pro-series/products/zd000677). 12,000 lumens, it's pretty powerful for a 12" light bar considering that standard Halogen headlight bulbs put out about 1000 lumens in low beam.
As I post this, the 2-gallon air tank is still available. I'm asking $35, similar 2-gallon tanks sell for $80-90:
https://www.summitracing.com/parts/var-91022
Also the Bluetooth RGB halo headlights are also still available as is the mold that made the grille overlay seen in this video demonstrating the headlights:
—— New stuff...
In the process of doing the CJ Grille Kit for the TJ, I also did a Jeepster Commando hood to fit the TJ. I also did a replic Hurst Commando hood scoop. I just did these as an "art project", which is what I say when I make something just for the challenge of making it but I don't intend to use it. This is an original Hurst Commando:
I did test install it on my LJ, here are a few photos (in these photos I just set the hood in place; my CJ grille was installed so I also set fiberglass "Commando grille ears" in place to roughly simulate what it would look like with a Commando grille:
The original Hurst scoop had a tachometer in it; this replica has a mounting area that can hold two standard-size gauges:
The scoop posed on my LJ pickup:
Another view of the scoop:
The complete setup on my test tub in the workshop:
I've still got the hood, the scoop and a Commando grille and I don't plan to use any of them.
I'd like to see these go together so if anyone thinks a TJ Commando would be cool to have these may be for you - hood, factory Commando grille, and Hurst Commando hood scoop. Make an offer.
After the weekend I'm off to the Smoky Mountain Jeep Invasion so this is the last post I'll do offering items for sale until I get back from the show.
