The TJ Mirror Company auto dim / temp / compass mirror one month review
MikekiM
TJ Expert
East of Montauk, NY
After a month of use with the Double Din Auto Dimming mirror with temperature and compass from The TJ Mirror Company I have some thoughts on the experience worth sharing.
TJMC offers a few versions of the auto-dim mirror.. Base model has just the compass display and no provisions for ambient temperature. The top of line model has both compass direction and ambient temperature displayed all the time. Between the two is the model that has both compass direction and ambient temp but only one is displayed at a time, with switching between the two done by pressing the appropriate button on the front of the mirror. Kits are priced at $100, $180 & $200 respectively. I bought the top of the line model.
The unit itself works just fine.. after all it’s a mirror. The slightly larger size when compared to the stock TJ mirror is welcome and the unit can be angled up higher than stock as well, so greater forward visibility. Its larger size means the sun visors hit the mirror, but it is a non-issue. The included harness is plenty long to reach the grill. Though I requested the harness for a 2000 TJ, the last five to six inches of the harness that runs around the windshield was unfinished and bare wires were visible where the harness enters the upper dash and had to be wrapped with expanded sheath so as to not look like crap. TJMC said they likely sent me the kit for the later TJs with the windshield trim. Otherwise the detailed install instructions made it all plug and play.
The auto dimming feature works perfectly. It’s bright and clear when ambient light is high and once it gets dark and the unit sees bright lights it dims just enough.
The compass has proven to be very accurate. No complaints there.
And so we come to the temperature. The temperature display has been inaccurate since the day I installed the kit. It displays a temperature that is consistently five to ten degrees warmer than all other temps I can cross reference to. Doesn’t matter if the Jeep is sitting or moving. The install instructions note that the temp sensor is most accurate at speeds greater than 8mph. I find speed doesn't make a difference either way.
I contacted The TJ Mirror Co and explained the situation and that even at cold start in the morning after sitting all night the temp is half a dozen degrees off. They agreed to send me a new sensor which I installed in the recommended location (behind the grill, mounted up high at drivers side) and that didn’t help. I removed the silly grill inserts the OP had installed on my Jeep (which I had left installed only because the paint damage on the grill caused by dirt trapped behind the inserts was more annoying than the look of the inserts) and that didn’t help. Last, I relocated the sensor up under the drivers side front fender (suggested by @Woodrow) and that did nothing. So I mentally dismiss the temperature when I look it.
Would I buy this piece of kit again? Yes. I like the larger display of the mirror & the auto-dim works as expected. Would I buy the Double Din unit with compass and temperature? No. If I could turn off the temp display on this unit and use only the compass I would but it’s either both or neither displayed. If I were to do it again I would opt for the base unit that is auto-dim and compass display only for half the price.
I may opt to unplug the ambient temp sensor altogether and go with the expected " - - " in the display.
Appreciate the feed back! I am wanting to add something like this to get external tempature. I have had several vehicles with the factory sensor and one other aftermarket. They always see a little off on temp during a sunny day. Car getting warmed by the sun, as you noted, the temperature comes to more accurate when moving. that doesn’t explain the fact that you’re consistently off but just saying that they’re not always entirely accurate. I use them as more of a ballpark figure around here. I’m just concerned when the temperatures are getting close to freezing.
If the inaccuracy is caused by a shitty sensor then you could use a better sensor. This one fits my 2004.
https://www.amazon.com/dp/B07F489DGZ/?tag=wranglerorg-20
Just FYI that's a standard GNTX mirror. I hunted up a version with a red display to match everything else and made sure it had Homelink 3 so it can open my newer garage door.
Cool...you have a link to where you purchased yours?
Any modifications to get it to install or did it attach straight to the mount on the windshield?
@MikekiM, do you have the original PCM or an aftermarket? The reason I ask is made my own kit using a mirror and sensor from a GM truck with a wiring harness I made myself. It worked well and had the usual higher than normal temps when sitting still for a while but would go back to a more accurate temp after moving for a bit. This was with the factory PCM. Sometime later I needed to replace the PCM due to the hard 1-2 shift. I don't know how long it was after replacing the PCM it was that I noticed the temp was way off all the time, but it was at least a month or two. I tried a couple new sensors with the same results. Got tired of seeing the way off temp so I put the auto dim and compass only mirror that used to be in my truck in there. I did the same mod to my truck with a junk yard mirror and sensor years ago and it's still working well.
More recently, I got to wondering if since my Jeep didn't originally come with the temp mirror, if it's something that has to be in the PCM for it display properly? I kind of doubt it since it initially worked with the OEM PCM and my truck still has its original PCM and neither came with that option.
@Wranglerfix , can you confirm if the PCM has anything to do with the mirror outside temperature display in the mirror.
Jeep sits and cools overnight. I come out this morning and Apple IOS says 67, Weather.com says 67. The mirror says 73.
I wonder if there's a way to plus minus the temperature via firmware or a secret menu via button pushes.
If there is, you would think the install instructions would note or, the manufacturer might have told me rather than send me another sensor. There are a few other 'cheats' listed in the instructions, but nothing regarding calibration of the temp.
Yes, it is a standard GNTX mirror.
My house (garage door) is Smart and is programmed via Apple HomeKit. No buttons to push.
Can't say for sure. I haven't changed the PCM in the time I own the TJ.
The mirror comes with a new harness made by the TJMC. They are specific in the install instructions that their harness should be used even if there is an existing mirror harness installed. I didn't have the OE harness.
As far as I know, it's an OE sensor, mounted in the OE bracket in the OE location.
Reactions: MountaineerTom
I just researched which version I wanted and ordered from ebay. I had already installed an older GNTX previously so I already had all the wires I needed running to the mirror. Same windshield button I believe so it slipped right in. Just had to rewire to the new harness plug.
Have you compared your Jeep temp to another thermometer at the same location? I have noticed my outdoor home thermometer doesn’t exactly match the wife’s iPhone reported temperatures, which I suspect is due to location differences.
I did. I have an infrared thermometer. Even the body panels near the sensor are at a lower temperature than what the mirror display shows.
iPhone is likely using the nearest official weather station, could be the nearest airport. If your house is at a higher or lower elevation than that weather station then you will have a different temperature. I see this between KTUS temperature and my house.
Andy
Reactions: freedom_in_4low
Nice review. Thank you. Stuff like this is very helpful. I’m bummed changing the sensor location didn’t help. I’m going to try something like this eventually (bogged down on door hinges, stereo, armor and atlas for the foreseeable future). When I do, I’ll definitely keep all of this in mind and let you know how it works out.
Reactions: MikekiM
Wow - I didn't realize upgrading to a dimming mirror would improve performance so much. Andy
Then throw in one of those 40 mpg oil filters and a guy would be golden!
I have a Gentex out of a Suburban I installed and as far as I know the temp has been accurate.
I made my own harness, so it's now through the PCM at all.
Reactions: hear and tr21triton
There are two ambient temp sensors - one for the PCM and one for the mirror. Did you reuse the PCM one for the mirror?
Andy
Reactions: J.Pierce
