For those that can't math and don't know, that difference in the 2 final ratios is 5% or 1 gear step. In other words, if you wanted similar RPM at a given speed on the same size tire, you would gear the AX 1 step lower than the NSG 370. I did not consult any feelings to arrive at those numbers.♧ My notes have my final 6th at 0.84
The Ax15 5th gear was 0.79.
I don't remember this forum being this rude. Sign of the new times. I'm just not in the camp of enjoying running down the freeway at 3500rpm at any speed. If you all can afford that, cheers to you and your oil stocks.
Ive got a 03 with nv3550 and 30/44 combo and regeared to 4:88s as I was on 33's but soon after found some 35s for a good price. I only went with 4:88 until I find a front axle so then i can put 37s and then regear to 5:38's
You are limited to 5.13’s with your 30. And neither the 30 nor the 44 is really up to 37’s. 35’s are fine with the right shafts.
Also, my understanding is that I would lose some ground clearance going to a Dana 44 over the Dana 30 that I kept. Am I right on that?
I would have liked to have gone with a 5.38 ratio but costs of swapping to a Dana 44 front were high so kept my Dana 30. I have been happy with the 5.13 ratio I went with.
5.13s with your 35s and 5-speed is a pretty optimal choice.
However, I think you should have upgraded your tie rod from 5.13 to 5.38![]()
I have the currectlync
3k rpms at 75 with the transmission in 6th???I got a chance to use the 4.88s on the rocks and up and back from the mountain. I really am enjoying the 241s 4to1 first gear. I did notice i was shifting in and out of 4wd on the straight trails. Before I just ran the gears in low.
On the highway I was in 4th and 5th most of the way up. Pegged in 6th on the way down.
37s and 4.88 puts me at 3000 rpm at 75. It's a happy medium for me.
