Looks pretty good. The body especially looks clean. The good thing about a jeep is that you can look at the fault codes yourself if your check engine light comes on. If you quickly turn your key from off to accessories (3 times in 5 seconds) the code will display on your odometer. Google the code that comes on and you’ll find a ton of info on what it means and how to fix it. It’s a good way to check how honest or knowledgeable a mechanic shop is.
Unless I'm mistaken I don't think you can do that on the 2000, I think so later and some earlier TJ's you could. I'll probably be buying a gizmo to read them soon though. The mechanic said it looked like rust a misfire but we'll see if it pops up again.
