What problem are you trying to address that will be solved with a subframe? Start there.
Can I answer that?
Can I answer that?
Only if your answer validates a presupposition in favor of a subframe.![]()
Can I answer that?
What does subframe mean?
Typically you cut the TJ frame off at where it goes up at the front of the rear wheel arch at some level right below the bottom of the tub floor. Then you slap two straight frame rails to the inside face of those cuts in some manner that attaches them and they shoot out the back to a rear crossmember that supports the rear of the tub. It is done to get the OEM frame out of the way for coil overs and so you don't have to deal with moving the wheel arch to keep it centered over the axle if those things matter to you.
Which part was non factual?
Me personally? Nothing. Just trying to find facts and numbers on why they are bad or good. These jeep platforms are somewhat new to me. Building a link suspension is not.
I guess a case could be made with wanting to be a "bolt on build" but that would be false as all the subframe or pretty much anything short of short arm lift is not a bolt on project.
The part where he asked what a subframe was and you gave him the facts of a back half which is not required all the time.
Stupid question. But Ill play along.
Its not when your posting pics of basically a U4 car with zero TJ parts.
Thank you. I learned a new thing.
Maybe, substitute back half for "subframe". Apparently we are calling the belly-skid set ups like the RE belly pan a sub frame. We have never used that term once so I probably fucked that up.
