Water pump lifespan
xXDavidCXx
AZ
I just replaced my mopar water pump 68382489AA with a gates replacement.
The pump lasted 13 months and 14k miles.
Is that normal?
  • Wow
Reactions: BlueC
Is that normal?
No, not normal. What’s the fluid look like?
Was it a true mopar? I bought what I thought was a mopar pump from wermopar.com in 2016. In 2021 after 60k miles it failed. Turns out there were no Chrysler/mopar indicators on the pump. I've since gone with a Gates. It has maybe 5,000 miles on it though.
Me too on the Gates pump, a few weeks ago it was like $23 on Amazon, time will tell.
easy install except for the broken bolt at the 12 o’clock position.
I've had issues with metallic particles in the fluid. I spent weeks (years ago) flushing and replacing parts and I made some headway on getting rid of the particles. And yes, I flushed using prestone/thermocure and using the block hole too.
Old unit
To be clear, it didn't fail or leak, but it was the source of squeaking under the hood that I wasn't going to live with, and it was getting worse.
What’s the fluid look like today as far as “metal particles”?
Water pumps are one of those "you never know" situations. I always replace them when I get a new to me vehicle - the one time I didn't, it failed in fairly short order. I knew better, and it bit me in the ass. It was my TJ! I replaced it with a Gates.
I've seen them go 150K miles, or fail at under 1K - and everything in between. Just luck of the draw I guess. My old MBZ got a new pump with the engine rebuild at 298K. At 315K, the pump grenaded - I never saw anything like it. The bearing was completely gone, the fan was wobbling around, yet it didn't leak any coolant. I probably drove it 50 miles like that before I knew there was a problem!
My water pump went a couple weeks ago so I just went through a bunch of reading to decide on brand, didn’t wanna spend $300 on a Mopar.
Some guys have had no issues with Gates/Napa (made by Gates), some have had them go out prematurely which is why I steered away from Gates, even though it’s a reputable brand.
I’m gonna be replacing mine this weekend, I ended up deciding on an ACDelco, Made in US plus a metal impeller.
I installed a Gates almost exactly 3 years ago. IDK how many miles, but I drive it pretty regularly around town. Mine definitely had a metal impeller (since somebody else brought it up).
