If you have the 6-speed, it’s a bit harder to move the console back 1”. It can be done, but your limit is where the back console cup holders will run into the tub. You also have to drill new holes in the lower boot that mounts to the transmission tunnel so it will move back 1”. Otherwise that boot will be torn to shreds, and they’re either very expensive or unobtanium. You can also remove and bend the shifter forward so it misses the bezel on 2, 4, 6, and R.
Lifting the Transmission with a spacer should help too. I’d think an inch would be better than nothing. Of course a TT would solve it. That’s what I eventually did. Then everything was back to normal.
Good luck.
