Kiwi TJ
Just asked myself if I’m crazy and we all said No
Gravy on the veggies - rock on, Kiwi TJ!![]()
I like to live on the edge haha
I aired up the tires from 24psi to 29psi. Hopefully that increases the gas mileage a bit so that it goes from 11mpg to 11.5mpg.
damn and I've been complaining about the 14-15 I'm getting ! guess I'm spoiled by the 18+ I get in my Sahara ....
Must be the colour matched flares on that Sahara that give you less wind resistance![]()
That is about the same that I get with my 05 LJ, 11.0 - 11.5 MPG.
Gonna ask here. What Black Max shocks for a 4" lift? Overwhelmed on the search function for a specific answer. Please help if you know.
| Driver | Passenger | |
| Minimum (Compressed) | 16" | 15 3/4" |
| Ride Height | 21 1/2" | 21 3/4" |
| Maximum (Droop) | 27" | 27 1/4" 28" (w/ Driver High) |
| Total Travel (Max - Min) | 11" | 11.5" (12.25") |
| P/N | Collapsed | Extended | Typical Lift |
| B8516 | 13.54 | 22.75 | 0-3" |
| B8525 | 14.52 | 24.3 | 4-5" |
| B8549 | 16.56 | 28.75 | 6-8" |
| B8549 | Driver | Passenger |
| Max Up (Larger of [Shock Collapsed] or [Min Front Measurement]) | 16.56" | 16.56" |
| Ride Height | 21.50" | 21.75" |
| Max Down (Smaller of [Shock Extended] or [Max Front Measurement (Droop)] | 27.00" | 28.00" |
| Up Travel | 4.94" | 5.19" |
| Down Travel | 5.5" | 6.25" |
| Total Travel | 10.44" | 11.44" |
| % Up / Dn | 47% / 53% | 45% / 55% |
| B8525 | Driver | Passenger |
| Max Up (Larger of [Shock Collapsed] or [Min Front Measurement]) | 16.00" | 15.75" |
| Max Down (Smaller of [Shock Extended] or [Max Front Measurement (Droop)] | 24.30 | 24.30 |
| Up Travel | 5.50" | 6" |
| Down Travel | 2.80" | 2.55" |
| Total Travel | 8.30" | 8.55" |
| % Up / Dn | 66% / 34% | 70% / 30% |
| Minimum (Compressed) | 16 3/4" | 18 1/8" (w/ Driver spring Installed 18 1/2" (w/o Driver Spring Installed) |
| Ride Height | 22 1/4" | 22 1/4" |
| Maximum (Droop) | 26 1/2" | 29 3/4" |
| Bump Stop | Currie = Good | Currie Needs 1" Added |
| Total Travel (Max - Min) | 9.75" | 11.625" (11.25") |
| B8518 | 13.71 | 22.58 | 1-3" |
| B8528 | 14.82 | 24.84 | 3.5-4" |
| B8563 | 15.94 | 27.07 | 6-8" |
| B8563 | Driver | Passenger |
| Max Up (Larger of [Shock Collapsed] or [Min Front Measurement]) | 16.75" | 18.125" |
| Ride Height | 22.25" | 22.25" |
| Max Down (Smaller of [Shock Extended] or [Max Front Measurement (Droop)] | 26.50" | 27.07" |
| Up Travel | 5.50" | 4.125" |
| Down Travel | 4.25" | 4.82" |
| Total Travel | 9.75" | 8.945 |
| % Up / Dn | 56% / 44% | 46% / 54% |
| B8528 | Driver | Passenger |
| Max Down (Smaller of [Shock Extended] or [Max Front Measurement (Droop)] | 24.84" | 24.84" |
| Down Travel | 2.59" | 2.59" |
| Total Travel | 8.09" | 6.715" |
| % Up / Dn | 68% / 32% | 61% / 39% |
I had the same issue when I put in my Currie/Savvy 4" lift within the past year. Many different answers - and that's the answer. You need to flex your suspension with the tires on and the springs removed. Measure to find out what is best for your rig.
With my 1.25" BL and 4" SL with GR 4" flare tube fenders, I went with:
Front: B8549
Rear: B8563
Here's the data I collected on my setup as an example of what you should do to find out what is right for you. [Your measurements will be different than mine - data here is for reference as an example]
Front Measurements
Driver Passenger Minimum (Compressed) 16" 15 3/4" Ride Height 21 1/2" 21 3/4" Maximum (Droop) 27" 27 1/4"
28" (w/ Driver High)Total Travel (Max - Min) 11" 11.5"
(12.25")
Skyjacker Black Max - Front
P/N Collapsed Extended Typical Lift B8516 13.54 22.75 0-3" B8525 14.52 24.3 4-5" B8549 16.56 28.75 6-8"
Travel With Shock
B8549 Driver Passenger Max Up (Larger of [Shock Collapsed] or [Min Front Measurement]) 16.56" 16.56" Ride Height 21.50" 21.75" Max Down (Smaller of [Shock Extended] or [Max Front Measurement (Droop)] 27.00" 28.00" Up Travel 4.94" 5.19" Down Travel 5.5" 6.25" Total Travel 10.44" 11.44" % Up / Dn 47% / 53% 45% / 55%
B8525 Driver Passenger Max Up (Larger of [Shock Collapsed] or [Min Front Measurement]) 16.00" 15.75" Ride Height 21.50" 21.75" Max Down (Smaller of [Shock Extended] or [Max Front Measurement (Droop)] 24.30 24.30 Up Travel 5.50" 6" Down Travel 2.80" 2.55" Total Travel 8.30" 8.55" % Up / Dn 66% / 34% 70% / 30%
Rear Measurements
Driver Passenger Minimum (Compressed) 16 3/4" 18 1/8" (w/ Driver spring Installed
18 1/2" (w/o Driver Spring Installed)Ride Height 22 1/4" 22 1/4" Maximum (Droop) 26 1/2" 29 3/4" Bump Stop Currie = Good Currie Needs 1" Added Total Travel (Max - Min) 9.75" 11.625"
(11.25")
Skyjacker Black Max - Rear
P/N Collapsed Extended Typical Lift B8518 13.71 22.58 1-3" B8528 14.82 24.84 3.5-4" B8563 15.94 27.07 6-8"
Travel With Shock
B8563 Driver Passenger Max Up (Larger of [Shock Collapsed] or [Min Front Measurement]) 16.75" 18.125" Ride Height 22.25" 22.25" Max Down (Smaller of [Shock Extended] or [Max Front Measurement (Droop)] 26.50" 27.07" Up Travel 5.50" 4.125" Down Travel 4.25" 4.82" Total Travel 9.75" 8.945 % Up / Dn 56% / 44% 46% / 54%
B8528 Driver Passenger Max Up (Larger of [Shock Collapsed] or [Min Front Measurement]) 16.75" 18.125" Ride Height 22.25" 22.25" Max Down (Smaller of [Shock Extended] or [Max Front Measurement (Droop)] 24.84" 24.84" Up Travel 5.50" 4.125" Down Travel 2.59" 2.59" Total Travel 8.09" 6.715" % Up / Dn 68% / 32% 61% / 39%
Front: B8549
Rear: B8563
Front Measurements
(12.25")
Travel With Shock
Rear Measurements
(11.25")
Travel With Shock
There’s no way I did this to figure out which 5000’s to buy.
I like the Maximum Strength Blinker Fluid. Amazon has it:
[URL]https://www.amazon.com/dp/B06ZXSKDZG/?tag=wranglerorg-20[/URL]
It gets boring. I eat the same thing every meal, every day. Doctors' orders.What - no pictures with food in it? Asking for a friend (you're welcome, @Kiwi TJ!)...
Yeah c'mon @TheBoogieman your losing your touch haha...I'll help you out with a pic of my Christmas dinner
(and yes even a Kiwi Christmas with 77 degrees and humidity through the roof we still have a full roast with turkey)
