Getting ready to add something to the garage.
damn and I've been complaining about the 14-15 I'm getting ! guess I'm spoiled by the 18+ I get in my Sahara ....
Must be the colour matched flares on that Sahara that give you less wind resistance 😂
Gonna ask here. What Black Max shocks for a 4" lift? Overwhelmed on the search function for a specific answer. Please help if you know.
I had the same issue when I put in my Currie/Savvy 4" lift within the past year. Many different answers - and that's the answer. You need to flex your suspension with the tires on and the springs removed. Measure to find out what is best for your rig.
With my 1.25" BL and 4" SL with GR 4" flare tube fenders, I went with:
Front: B8549
Rear: B8563
Here's the data I collected on my setup as an example of what you should do to find out what is right for you. [Your measurements will be different than mine - data here is for reference as an example]
Front Measurements
DriverPassenger
Minimum (Compressed)16"15 3/4"
Ride Height21 1/2"21 3/4"
Maximum (Droop)27"27 1/4"
28" (w/ Driver High)
Total Travel (Max - Min)11"11.5"
(12.25")
Skyjacker Black Max - Front
P/NCollapsedExtendedTypical Lift
B851613.5422.750-3"
B852514.5224.34-5"
B854916.5628.756-8"
Travel With Shock
B8549DriverPassenger
Max Up (Larger of [Shock Collapsed] or [Min Front Measurement])16.56"16.56"
Ride Height21.50"21.75"
Max Down (Smaller of [Shock Extended] or [Max Front Measurement (Droop)]27.00"28.00"
Up Travel4.94"5.19"
Down Travel5.5"6.25"
Total Travel10.44"11.44"
% Up / Dn47% / 53%45% / 55%
B8525DriverPassenger
Max Up (Larger of [Shock Collapsed] or [Min Front Measurement])16.00"15.75"
Max Down (Smaller of [Shock Extended] or [Max Front Measurement (Droop)]24.3024.30
Up Travel5.50"6"
Down Travel2.80"2.55"
Total Travel8.30"8.55"
% Up / Dn66% / 34%70% / 30%
Rear Measurements
DriverPassenger
Minimum (Compressed)16 3/4"18 1/8" (w/ Driver spring Installed
18 1/2" (w/o Driver Spring Installed)
Ride Height22 1/4"22 1/4"
Maximum (Droop)26 1/2"29 3/4"
Bump StopCurrie = GoodCurrie Needs 1" Added
Total Travel (Max - Min)9.75"11.625"
(11.25")
Skyjacker Black Max - Rear
B851813.7122.581-3"
B852814.8224.843.5-4"
B856315.9427.076-8"
Travel With Shock
B8563DriverPassenger
Max Up (Larger of [Shock Collapsed] or [Min Front Measurement])16.75"18.125"
Ride Height22.25"22.25"
Max Down (Smaller of [Shock Extended] or [Max Front Measurement (Droop)]26.50"27.07"
Up Travel5.50"4.125"
Down Travel4.25"4.82"
Total Travel9.75"8.945
% Up / Dn56% / 44%46% / 54%
B8528DriverPassenger
Max Down (Smaller of [Shock Extended] or [Max Front Measurement (Droop)]24.84"24.84"
Down Travel2.59"2.59"
Total Travel8.09"6.715"
% Up / Dn68% / 32%61% / 39%
Front: B8549
Rear: B8563
Front Measurements
DriverPassenger
(12.25")
B851613.5422.750-3"
B852514.5224.34-5"
B854916.5628.756-8"
Travel With Shock
Up Travel4.94"5.19"
Up Travel5.50"6"
Rear Measurements
DriverPassenger
(11.25")
B851813.7122.581-3"
B856315.9427.076-8"
Travel With Shock
There’s no way I did this to figure out which 5000’s to buy.
Reactions: John Cooper
Front: B8549
Rear: B8563
Front Measurements
DriverPassenger
(12.25")
B851613.5422.750-3"
B852514.5224.34-5"
B854916.5628.756-8"
Travel With Shock
Up Travel4.94"5.19"
Up Travel5.50"6"
Rear Measurements
DriverPassenger
(11.25")
B851813.7122.581-3"
B856315.9427.076-8"
Travel With Shock
Cant Argue Schitts Creek GIF by CBC
Reactions: RINC and FarFire70
As you can see on the SJ recommended height lift - any company is giving a best guess on which shock will fit your lift. But we see lifts give 0.5-1" of extra lift regularly.
I wanted a 50/50% up/down travel that minimized travel in either direction.
Best way is to flex it out so you ensure the shocks aren't limiting your droop.
If they're undersized for the up travel & you don't have the right bump stop... the shock will let you know at that point... 💥
Reactions: Weasellee
Yeah c'mon @TheBoogieman your losing your touch haha...I'll help you out with a pic of my Christmas dinner :p
(and yes even a Kiwi Christmas with 77 degrees and humidity through the roof we still have a full roast with turkey 😓 )
Show off! I dropped some of my turkey Christmas dinner and a friend ate it.
