Hi,
I just picked up a TJ with a 2001 5.9 Magnum and 46RE from a ram 2500 using the ram pcm and 4.10 gears/35" tire. I am trying to chase down and fix some things that don't seem quite right. The main issue I am running into is when it kicks down into passing gear going up hill it doesn't really go any faster. Just revs up and screams like a banshee but doesn't move much more then before. The shifter is a b&m ratchet shifter but I don't see any button anywhere for an overdrive so I think I need to figure out how to add a overdrive button, not really sure if this could be causing the issue or if there is something else not set up correctly. Anyone have some ideas on what to look for or am I expecting too much out of the 5.9 and this is normal?
