1. Having more droop on the passenger side (rear axle) is 100% normal. When you do the front you'll see the same thing on the driver side.
2. Sahara flares are 1" wider, same width as the Rubicon. I have rough country flares which are Rubicon width, because they were easier and cheaper to get my hands on, but they're not as nice as the real thing.
3. Rockjock springs won't fix the rear passenger sag. I just put brand new ones on mine and still have it. I don't have a good explanation for why, but I think I've come to reject the common explanation that it has anything to do with the engine torquing that way. The engine does torque that way, but I had a 1/2" as soon as it was on its own weight, having never even been started up.
4. I think you'll want the 0-2" JKS bar for the Sahara. The 2.5" probably won't let you adjust it short enough, and may even be bent in a way that requires extra bump stop which wouldn't be good on a stock jeep that has 4" or less of uptravel to start with. I would buy the one from @Mike_H and try your other one on the LJ, or if you've already bought the Rockjock, sell the JKS.
I have a JKS bar sitting here that is the one designed for the shorter lift height (0-2, I think). Its dirty, but functional. PM me if you're interested.
Does the 0-2" one utilize the same style drilled mount?
If so, I want to hop on that and buy it from you.
I'm really just looking to get it functionally roadworthy, but correct.
I don't feel good about selling someone a hack-job. So this seems to be a good "correct" way to fix the issue entirely.
I'm not sure if JKS sells the 0"-2" version anymore. All I can find is the 2.5"+ "HD" version.
Yeah, same joints and everything...Its just shorter on the tubing side (the black part with the "johnny joint")
I don't have that little wedge washer...but its totally unecessary, as well.
I'm not sure what causes it on the TJ/LJ platform. Right now, it's sitting a the same level both sides. But I KNOW for fact that it was sagging 1/2" before I removed them from the TJ, so I expect the issue to come back. I'll more than likely just get a small spacer to level it out on the sagging side.
Keep in mind the weight of a driver probably evens it out, or maybe even reverses the difference, and I care more that it's even when driven than when parked. Or at least that's what I tell myself to be ok with leaving it alone.
Just a little side-question about the front suspension.
Is it "normal" for the spring to contact the bump-stop cup?
Judging by the suspension geometry, I've concluded that it IS normal at this lift height (4"), but I guess to dive deeper into the topic, is there any way to fix it?
You’re supposed to drill and tap the LOWER perch and put your bumpstop down there rather than up top. That will eliminate the rubbing.
It didn't for me. This was a stock upper bump stop and perch with extension only added to lower.
My final adjustment might have helped a bit, but I know I at least had the bump stops lined up here, so it would only have been final caster and axle squaring at ride height.
This was hanging from a fully extended 11" Rancho.
It’s way worse with the bumpstop above the cup.
Is that simply a consequence of short arms at that lift height, or is the axle mounted too far back?
