Did not pass NYS inspection
The TSB does not mention the Evap System Monitor, and the evap system isn't related to the three monitors mentioned in the TSB, so I doubt that doing the TSB fix will address the Evap System Monitor not promoting to Ready status. The evap system is checking for fuel vapor leaks, while the TSB addresses three monitors that check for exhaust emissions system issues (catalytic converter performance and O2 sensor performance).
That said, I haven't myself confirmed, nor have I seen any other forum user confirm, that the TSB does or does not address Evap System Monitor readiness, so I'm only making an educated guess here.
Also, in some states, you can pass emissions with a single Monitor with a status of "not ready." So, if you do the TSB and fix the emissions readiness issue, you may be able to pass without the Evap System Monitor ready.
Yes, both cleared. Monitor EVAP Not Ready and Monitor Heated O2 Not Ready
joe
Reactions: Weasellee and sab
joe
Interesting! Thanks for chiming in. I think I'll have to do the TSB on mine and experiment some time (not soon - I'm just about to start my build, and I think the LJ will be on my lift for months...) I never did the TSB fix because we don't have emissions testing in my county (though if I lived 1.5 miles south, I'd be in a county that does - that's the craziness of government regulations). Also, our legislature recently did away with mechanical inspections starting next year, so I'll be free at last, free at last, free at last!
Did the TSB also clear your evap not ready as well?
I have an 06 LJ 6 speed with the exact same 2 not ready states that now has to go through emission testing here in IL.
Any help appreciated!
Mine had the O2 and Evap monitors not clearing for many months. After the TSB mod, the O2 monitor cleared immediately on starting. But the Evap monitor needed a short drive around the neighborhood before it cleared.
I checked an older and newer version of the TSB, and neither mentioned Evap. But apparently, Evap gets cleared by this mod, too.
Thanks for the feedback. I’m planning on replacing the radio so will be disconnecting the battery and figure will do the TSB at that time.
can’t thank everyone enough for the excellent support on this site.
I did a little reading up on this issue this afternoon. I think the Evap System Monitor, which is run all the time (not just once) won't run if there are any pending or permanent DTCs set, so that may be how it is affected (indirectly).
So everyone i spoke to about doing the wire splicing was reluctant about doing it. Me too!
But I was tired of waiting so I tried it myself Saturday, drove it Sunday and today.
SUCCESS - All cleared and Passed NYS inspection!
Thanks to all you guys for the info and the TSB
Joe
Feels good eh?
Interesting.
Makes sense now as to why evap also not ready.
I've also learned that the TSB mod is pretty simple in what it does. Originally, the factory powered the positive side of the Automatic Shutdown (ASD) relay's coil via the Run and Start positions (so that the coil can only change the state of the relay if the key is in Run or Start). Then, the negative side of that coil is controlled by the PCM (it grounds it, to complete the energization, and keeps it grounded as long as the engine starts within 2 seconds and stays running).
The TSB changes the wiring so that the ASD relay coil's positive side is powered from Fuse 9 in the PDC. Fuse 9 is always hot (as long as the battery is connected), so the key position doesn't affect the ASD relay energization.
The Factory Service Manual (FSM) says that the O2 Sensor Heater Monitor processes some data when the PCM is powered down (after the ignition key moves to the off position, but before the PCM goes to sleep). I haven't been able to figure out why (there's conflicting information in the FSM), but apparently, those two sensor's heaters need to keep their positive side energized beyond the key off time. That is what the TSB mod does - it keeps them powered all the time. It must have something to do with how that data is collected right up until power down. If the heater power is lost, the processing never completes, and the monitor is never "Ready."
Interesting!
