I was a little nervous about the sway bar link bracket hitting the track bar bracket at full articulation, so I checked it. No problem.
Checking clearance with the tire, it does actually interfere with the bolt for the upper link heim. Only a problem at full articulation, full steering, and AR position 2. The tire just barely grabs the bolt but I think I can do better. This is with 1/2" of extra spacing behind the wheel.
I removed the 3/8" spacer and replaced it with one I machined down to about 1/8". Enough clearance that nothing touches now.
So I removed the 1/2" wheel spacer and put in a 1/4" one, back to where I started, as expected. I'm thinking I can put a button head screw here and have it clear just fine, or if not, it will at least have a rounded head to not catch on the tire lugs. It might limit the heim's misalignment ability, but I don't think I'll need it, everything stays pretty straight throughout travel.
I'd like to stick with the 1/4" wheel spacer because it makes it a lot easier to mount the wheel. With a 1/2" spacer, it covers up the center hub on the unit bearing, plus I am having a hard time finding wheel studs that are the right size. One other issue with the 1/4" spacer though is the tire hits the shock a little, but only at full lock steering and full articulation. I don't think it would be enough force to cause any damage to the shock other than maybe scuffing it. The tire would just deflect.
Started tackling one job that I was dreading, got the cutout in the frame plated. I knew this was going to be tedious, and it was. Just made it out of separate pieces instead of trying to bend one piece. Probably should have built in a bit more clearance than I did, but it'll work.
Just gotta fully weld this up and hope it doesn't warp, then I'll weld it onto the frame for good.
