Wait til he gets the centercaps-
Take the switch toggle out of the switch and paint the bottom fully with black touch up paint. It will eliminate the on indicator showing when the dash lights are on. I've had to do this with all of my GCD switch toggles.Added backlighting to my GCD fog light switch.
I had extra bulbs from fixing my airbag switch indicator and repurposed a kids dead toy charger that had a pin just the right size to fit into the pigtail.
Backlight on switch off
Backlight on switch on
It’s looks better in person without the camera artificially magnifying the backlight.
Finally some warm weather in the Mitten, so tackling my front bumper in prep for the Warn 8000 I picked up on FB Marketplace for $100 and will be rebuilding this summer. PO welded the bumper to the front frame ends, then welded down the factory tow hooks for good measure. 6 cutoff wheels later, I have it all apart and will be prepping the bumper and painting it this week after work.
Since I had some room with the bumper off, decided to replace the (original, probably) sway bar bushings with Moog, which have been in the parts pile since Christmas. Of course, 2 bolts came out with Kroil and the breaker bar, 1 rounded over, and the last one is just spinning (spot welds on nut broke free inside the frame, I'm guessing).
Not sure how I'm going to get this off, at this point. Suggestions welcome!
Angle grinder on the head probably
Or maybe a Dremel tool with a cut-off wheel to the head of the bolt because of the tight space?
Got my new Sierra twill trilogy top.
Someone previously said they got one too and it fits the earlier wrangler model.
He is correct. Mine is an ‘02 and this is suppose to be for ‘03 and up
Yep its cracked, Yep it sucked, hands were a little greasy and it got away from me, luckily my Kwai Chang Caine (google if younger than 45) Like reflexes kept it from landing on me, for those that are interested it is a ford drive side drop NP 205
Would be if I was.Is this to show that you're smarter than a box of hammers? LOL.
