I have a rough country (I know I've heard they suck but it works for me) 3.25" suspension lift with a transfer case drop. I just installed a 1.25" body lift and MML. I'm having issues with the shifter hitting and wondering if I can remove the transfer case drop and it will fix that? But also my main concern is do I want the MML and the transfer case drop together or just one or the other? I haven't driven it yet to see if it has vibration but I wanted to see if having both would cause problems. I dont care so much about having the ground clearance if keeping the transfer case drop helps and if it helps I'll deal with the shifting problem. I do some light offroading but nothing that that will matter. I really just went with the body lift so I could clean underneath better and so it sits a little higher. Any help would be appreciated!
