If you want it to be just like an LJ, you’ll need to cut it in two spots. The LJ frame is 15” longer than the TJ, 10” of wheelbase and 5” behind the rear axle.
10" after the door, and 5 at the end? will I have to remove the rear cross member or just add 5" after it, or cut off at the cross member, add 5" build new gas tank support, then reweld the crossmember?
I would image if we were to just add 15 after the door, and leave the rear as is would require extending the brake lines?
I would imagine you need to move the rear cross member. I’d you add 15” after the door, your wheels won’t line up with the wheel well
Mike_H is correct, a TJ6 is not the same as an LJ. A TJ6 is the same as a 5" rear stretch on an LJ. It you are looking to drop an LJ tub on a stretched TJ frame you'll need to do the 10" before and 5" after the axle. As far as the details, you'll need to measure to get things right. The body mounts are a little different and other details will need to be looked at. It shouldn't be too hard but that depends on your skill level.
If you want to simply extend 15" in front of the axle then you'll need to extend brake lines and fuel line, cut the tub a bit, and get a new driveshaft.
I do not want to cut the tub, and would like to use the LJ brake, and fuel lines.
For the rear section, would it be easier to just leave that crossmember there and add 5" after it?
You can make the 97 frame work, you won't like how much work it is.My 04 LJ needs a new frame and I have a 97 TJ frame. Can I stretch it to fit? Something like a TJ-6? Can someone point me to the thread @mrblaine made comments on the TJ-6, I can't find it. will build this with an LS 5.3 engine.
Thanks for any and all input.
You are getting completely hung up on the small stuff that becomes very evident after you dive into the project. If you have both the 97 frame and the one that needs a frame, get them close to each other and get out your measuring device. The brake lines, fuel pump harness, brake cables etc. are easily solved and dealt with.
But, the only way to reuse what you have is to put everything in the same location on the 97 frame. You have a blueprint under the rig now, use it.
Personally I would try to find a good LJ frame and sell your TJ frame. It sounds like a lot of time, work and money to make what you have fit.
It is all able to be done. Mix and match whatever you need to in order to make it work, just know that some of the mixing and matching is more work than it needs to be. If you retain the early steering gear, you'll need the matching steering shaft off of the TJ.What if I retain the tj steering box and skid plate, the tj is complete, so I can reuse whatever that is needed.
I don't know that the number is exactly 10". I would find that number by measuring from the center skid bolt on a 03-06 TJ to some feature on the frame that gives me that number.I could cut the tj frame before the rear control arm, extend 10", put the LJ tub on, and extend the rear as needed base on where the lj tub sets.??
If I was going to attempt this, I would level the frame front to rear and then from the center skid bolt center, go straight back to a line squared down from the hole at the apex of the rear wheel arch. That will give you the exact amount you need to move the arch.
No, I did not say that at all.Yes, I could extend the tj frame, drop the lj tub on it, and resuse the steering gear, shaft and skip plate. Move the fuel and brake lines etc of the lj etc.
The tj already has a lift, dana 30/35 geared at 4.88 with 35".
For the measurements, you are saying to line up the front of both frame and measure back?
Do the skid plates have the same dimensions?
I am just trying to visualize all in my mind.
