Does anyone have any advice on what joints are safe to use in a trackbar that is in a double shear configuration? It seems any trackbar with the adjust-ability on the frame end link can be used in a double shear configuration without effecting the way the body of the trackbar interferes with the rest of the components, but if the adjustable link is on the axle end, then this is not the case, as youll have to twist the entire body of the trackbar to get it to line up in normal double shear frame mount. So to that end, what are good candidates for joints to use on the frame end? How well does a johnny joint perform with its bolt in a horizontal position for a trackbar? To me it seems like mounting the joint in such a way would not allow it to behave the way it was intended in terms of articulation and shock absorption, but I'm really no expert. I ultimately wanted to use the rockjock trackbar with johnny joint end, but it seems this product may not work in double shear due to both issues I mention above 1. adjust-ability being on the axle end, 2. johnny joint with bolt in horizontal orientation (as seen in most double shear trackbar mounts), rather than vertical
