Success...
I knew that they were somewhere. They just weren't where they were supposed to be....
That's what happens when you organize... You never find it. You should always just lay them in the floor close to where you will need them..
At least it seems that's what I always end up doing and I find half of them on the other side of the shop.... LOL
Now let's get the fiberglass hood off so I can remove the hood pin latches and then get the steel hood mounted onto the Jeep so I can start the process of installing the hood pin latches on it.
You know if you just slam the hood a few times you'll get a pretty good witness mark where you'll need to drill the new pin holes.
I guess if you do it hard enough and enough times you'll get a really good tight fit...
Just saying...
