WranglerFix 2003-2006 Optimized Performance PCM
How much is it yo update a prior-purchase @Wranglerfix pcm?
It's my understanding is that it was $275 and now it's $350. At least if I am looking at the correct link on the Wranglerfix web site.
Original Link
I'm sure @Wranglerfix can confirm. If it fixes the shifts on that transmission, it's likely worth it. I will likely send mine out this week.
I just got a new one from Mark for my 05 6 speed and I specifically asked about the tune. I don’t want to speak for him but he did say that he doesn’t push them for the manual. They way he explained it to me it was more for the auto.
No idea on the manual but for those of us with an auto I would definitely recommend it also he is alot of fun to talk to if you have the chance
@Wranglerfix
what does the tune do if you have a manual 05-06 compared to the automatic transmission?
From the WranglerFix website:
"WranglerFix Optimized Performance PCMs are engineered for efficiency and power and are tailored to enhance throttle response, increase horsepower, torque across the entire powerband while improving fuel efficiency. With precise adjustments to ignition timing, fuel delivery, and other technical parameters, WranglerFix Optimized Performance unlocks the full potential of your vehicle, delivering a driving experience that is both exhilarating and efficient."
Would the optimize PCM change the recommended diff regear for an 05 LJ with a 42rle for 33s or 35s as listed in the chart here https://wranglertjforum.com/threads...angler-tj-lj-and-other-re-gearing-faqs.17063/
As I thought I read the higher ratios recommended for the 42rle were to help with the shift points in addition to more torque at the wheels.
Not really. The "performance tune" will not change performance enough to change the recommended gear ratio for a particular tire size.
As far as gear ratios, tire sizes and rpms are concerned, use this gear calculator rather than the chart:
www.grimmjeeper.com/gears.html
When inputting tire size, use "rolling radius x 2" rather than the published tire diameter. The results will be more accurate.
Rolling radius is the distance between the center of the hub and the ground with the tire inflated to normal street pressure.
If none of this makes sense, read this post:
https://wranglertjforum.com/threads/tire-size-measurement-methods.38648/post-641879
This is an anecdotal peripheral experience that relates to the gearing. My Jeep is on 35s with the 42rle and 5.38. That gearing is not deep enough. Recently, I added a supercharger with however much horsepower increase provided by it. Driveability is significantly better and makes the Jeep all the more delightful. Yet, I would still entertain the idea of 5.89, if the costs and risks involved were not as great as they are. Point being, WranglerFix is not squeezing out as much power as forced induction is.
From everything I have read about the WF 05-06 PCM, it is the changing of the shift points that will make the biggest impact. If this were available on the 03-04, I would pursue it immediately.
